Post Icy Phoenix Style To XHTML 1.1
I am trying to make the Icy Phoenix style XHTML 1.1 Strict compatible, currently on this site is is 1.0 Transitional and not XHTML-valid for the downloadable version. If people would like to help, post the before and after in this thread. Right now I am just adding CSS styles inline but when I am done, i will add them to the stylesheet.
1. Filename acronym_body.tpl
   Status: 1.1 but not semantic(inline styles)
   Before:
  1. <div class="forumline nav-div">
  2.     <p class="nav-header">
  3.         <a href="{U_PORTAL}">{L_HOME}</a>{NAV_SEP}<a href="{U_INDEX}">{L_INDEX}</a>{NAV_SEP}<a href="#" class="nav-current">{L_ACRONYMS}</a>
  4.     </p>
  5.     <div class="nav-links">
  6.         <div class="nav-links-left">{CURRENT_TIME}</div>
  7.         &nbsp;
  8.     </div>
  9. </div>
  10.
  11. {IMG_THL}{IMG_THC}<span class="forumlink">{L_ACRONYMS}</span>{IMG_THR}<table class="forumlinenb" width="100%" cellspacing="0" cellpadding="0">
  12.     <tr>
  13.         <th class="thCornerL">{L_ACRONYM}</th>
  14.         <th class="thTop">{L_DESCRIPTION}</th>
  15.     </tr>
  16.     <!-- BEGIN acronym_row -->
  17.     <tr>
  18.         <td class="{acronym_row.ROW_CLASS}" align="center" valign="middle"><span class="gen">{acronym_row.ACRONYM}</span></td>
  19.         <td class="{acronym_row.ROW_CLASS}" align="center" valign="middle"><span class="gen">{acronym_row.DESCRIPTION}</span></td>
  20.     </tr>
  21.     <!-- END acronym_row -->
  22.     <tr>
  23.         <td class="catBottom" align="center" colspan="2"></td>
  24.     </tr>
  25. </table>{IMG_TFL}{IMG_TFC}{IMG_TFR}
After
  4.     </p>
  7.         &nbsp;
  8.     </div>
  9. </div>
  10.
  12.     <tr>
  15.     </tr>
  17.     <tr>
  18.         <td class="{acronym_row.ROW_CLASS}" style="vertical-align:middle; text-align:center;"><span class="gen">{acronym_row.ACRONYM}</span></td>
  19.         <td class="{acronym_row.ROW_CLASS}" style="vertical-align:middle; text-align:center;"><span class="gen">{acronym_row.DESCRIPTION}</span></td>
  20.     </tr>
  22.     <tr>
  23.         <td class="catBottom" style="text-align:center; width:2pc;"></td>
  24.     </tr>
CivUnited
tonyf12Send private messageVisit poster's website
Post Re: Icy Phoenix Style To XHTML 1.1
2. Filename add_attachment_body.tpl
Befotre
  1.         <tr>
  2.         <th colspan="2">{L_ADD_ATTACH_TITLE}</th>
  3.     </tr>
  4.     <tr>
  5.         <td class="row1" colspan="2"><span class="gensmall">{L_ADD_ATTACH_EXPLAIN}<br />{RULES}</span></td>
  6.     </tr>
  7.     <tr>
  8.         <td class="row1"><span class="gen"><b>{L_FILE_NAME}</b></span></td>
  9.             <td class="row2"><span class="genmed"><input type="file" name="fileupload" size="40" maxlength="{FILESIZE}" style="width:98%" value="" class="post" /></span></td>
  10.     </tr>
  11.     <tr>
  12.         <td class="row1" valign="top"><span class="gen"><b>{L_FILE_COMMENT}</b></span></td>
  13.         <td class="row2"><span class="genmed"><textarea name="filecomment" rows="3" cols="50" wrap="virtual" style="width:98%" size="40" class="post">{FILE_COMMENT}</textarea></span><br />
  14.             <input type="submit" name="add_attachment" value="{L_ADD_ATTACHMENT}" class="liteoption" />
  15.         </td>
  16.     </tr>
After
  1.     <tr>
  3.     </tr>
  4.     <tr>
  5.         <td class="row1" style="width:2pc;"><span class="gensmall">{L_ADD_ATTACH_EXPLAIN}<br />{RULES}</span></td>
  6.     </tr>
  7.     <tr>
  8.         <td class="row1"><span class="gen" style="font-weight:bold;"></span></td>
  10.     </tr>
  11.     <tr>
  13.         <td class="row2"><span class="genmed"><textarea name="filecomment" cols="50" rows="3" style="width:98%; overflow:scroll;"  class="post">{FILE_COMMENT}</textarea></span><br />
  15.         </td>
  16.     </tr>
CivUnited
Thanks tonyf12,
In your post...
Before and After ?
Before -> Replace With ?
Greets
It is the entire file as most are only 15-30 lines long.
CivUnited
Ahh sorry, thanks again!
Thanks Tony,
I think the best way to create a fully XHTML 1.1 compatible template, is creating it from scratch, because the old templates have so many tables in.
What do you think about creating a new template from scratch?
This will allow us to create a fully compatible template and to rewrite the CSS in a more simple way.
If you agree we can start a working group which you may lead if you want.
Ok then but I haven't created a template from scratch before.
CivUnited
Where can I find the guideliness for XHTML 1.1 but maybe i can help you with conversion of icy templates to XHTML 1.1 but i haven't created a template from scratch before.
EDIT: I will help to have ca_aphrodite in XHTML 1.1 and for the next versions but I must read the information about XHTML 1.1 so I don't now how it works.
That would be great and really helpfull.
Thanks tonyf12, if you will give it a try.
brandsrus wrote: [View Post]
Here is the full specs: http://www.w3.org/TR/xhtml11/ . Mostly I just upload it to the validator, page by page
If you know XHTML 1.0 Strict here are the differences:
On every element, the lang attribute has been removed in favor of the xml:lang attribute (as defined in [XHTMLMOD]).
On the a and map elements, the name attribute has been removed in favor of the id attribute (as defined in [XHTMLMOD]).
The "ruby" collection of elements has been added (as defined in [RUBY]).
CivUnited
tonyf12 wrote: [View Post]
Ok, but how check you the pages if they are for the 100% XHTML 1.1? Can you give the steps?
Thanks in advance for your help!
If you go to http://validator.w3.org and upload to the validator or point it to a URL (if file is online) it will test it according to the DOCTYPE, if you don't have a DOCTYPE it isn't valid anbyway.
CivUnited
When I would like to validate the files, must i insert in all files the doctype or?
Yes the doctype goes in the html attribute and for xhtml1.1 is <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
Since I am starting a new theme for making an XHTML 1.1 template, has anyone any ideas what it should look like, a jpg mockup would be handy.
CivUnited
Thanks for your time to explain something about this scripttype.
If I understand begins the file with
  1. <html>
  2. <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
  3. <head>
  4. <title></title>
  5. <body>
  6. Contents
  7. </body>
  8. </html>
Thanks otherwise for your answers be so far!
