I have Icy Phoenix RC3 installed on my test board.
When a new user is created, the rank is automatically set to "Automatically change by no. of days", However all the ranks I created are set to change automatically by no. of posts.
Now my question: What do I do so that when a new user is created, the multiple ranks should set rank 1 as "Automatically change by no. of posts" and other ranks as " No rank assigned" ?
Thank you!
Multiple Ranks Problem
Subject: Re: Multiple Ranks Problem
You need to alter your DB the default fields.
Maybe something like this:
- ALTER TABLE `phpbb_users` CHANGE `user_rank` `user_rank` INT( 11 ) NULL DEFAULT '0'
- ALTER TABLE `phpbb_users` CHANGE `user_rank2` `user_rank2` INT( 11 ) NULL DEFAULT '-2'
- ALTER TABLE `phpbb_users` CHANGE `user_rank3` `user_rank3` INT( 11 ) NULL DEFAULT '-2'
- ALTER TABLE `phpbb_users` CHANGE `user_rank4` `user_rank4` INT( 11 ) NULL DEFAULT '-2'
- ALTER TABLE `phpbb_users` CHANGE `user_rank5` `user_rank5` INT( 11 ) NULL DEFAULT '-2'
Thanks i will try this.
EDIT: Thank MG..it works like a charm!
Now is there any way to change all users ranks to "Automatically change by posts"....those which registered before i made this change??
I got more than 5000 users and its impossible to change one by one?!?!
Of course there is a way...
This will reset all users rank to default... backup your DB first... :wink:
Whoa! i was waiting for this for a looong time!
Why dont you set this in the next release?
It is correctly set on new install... :wink:
toledo wrote: [View Post]
Generation Time: 0.2212s (PHP: 70% SQL: 30%)
