Title Modified: look at second post.
Hi to all.
I got this problems after migrating:
1) Quick reply doesn't work at all
2) The logout button has disappeared
3) I'm not able to access ACP anymore (I could just soon after the migration, but now i can't)
Thanks for support in advance :)
Problem With Cache
Subject: Problem With Cache
Subject: Re: Migrated From XS To Icy. A Lot Of Issues.
I've just figured out that is a problem about cache. After flushed my cache all those problems disappeared.
How can I fix this problem without disable the cache?
Subject: Re: Problem With Cache
damn, you're right, it wasn't setted properly (was 0)..
Let's try this way...
Regards ;)
Regards ;)
As I said so many times, Icy Phoenix now rely very much on cache... so when you have problems of this kind it is very likely that are related to cache, permissions to cache folder, permissions to def_* files, and so on.
Please, pay attention when installing/upgrading... read instructions twice, make backups twice... :wink:
Generation Time: 0.2588s (PHP: 7% SQL: 93%)
