www.garnertrojans.com
go to album, then test or test1, look at pic, they are not there even though the jpg is in the db
Pictures Don't Show
Subject: Re: Pictures Don't Show
You are using xs, and u got some broken files
Please since u are in icyphoenix.com, upgrade to icy and check if the error still exits
you are referring to
Package Name: Icy Phoenix
Package Version: 1.1.0.15
Thanks, I'll be upgrading this afternoon and let you know the results. I also have three other sites that need to be upgraded as well.
better keep thing up to date ;)
Good luck. Read the upgrading procedures :D
1. dowloaded zip to local machine
2. unzipped on local machine
3. ftp'd to directory on server
Error Condition:
2 files did not get transferred. perphaps corrupt in the zip
file 1: C:icyphoenixipincludesusercp_sendpasswd.php
and
file 2: C:icyphoenixiplanguagelang_englishemailtxtuser_activate_passwd.tpl
Can you supply them in some other manner.
Error Condition:
and
Another error cropped up. It was the same as with my previous version. The used table doesn't support FULLTEXT indexes. Someone had posted a replacement sql file that corrected that problem. Is there a substitute sql file for this version?
FULLTEXT is used for similar topics and comments for PA File DB...
I think you can just remove FULLTEXT things in the update script and run it again.
But remember that then you can't use similar topics.
Generation Time: 0.0857s (PHP: 21% SQL: 79%)
