I solved the problem I wrote before by installing the new ca_aphrodite...
...but, I get this error now:
Template->make_filename(): Error - template file not found: overall_header.tpl
The thing is that I have the file in the folder...
Is there something I can change in the database manually?
Thanks a lot!
I had the same problems...
I uploaded Aphrodite for Icy and had your same error. Try to clear cache.
Icy Phoenix is a HUGE CMS system, upgrading may cause some issue that could need some time to solve, but don't give up at the first try... your struggling trying to solve problems will be rewarded in satisfaction
The time now is Sun 21 Dec, 2025 22:23 • All times are UTC + 1 Hour
