[Template Bug? ] Some Issue With Global Blocks.
Subject: [Template Bug? ] Some Issue With Global Blocks.
I set a right column for global block and resized it a bit. These screens are from viewforum.php but I checked and it does the same in all the pages with global blocks enabled.
Result with FF (logged out):
Result with IE (logged out):
See that right blocks mess up.
Also, if I login (no matter if admin, mod or user. Also both with FF and IE) the right column disappears (blocks and page permissions are set to ALL, cache already emptied):
Subject: Re: [Template Bug? ] Some Issue With Global Blocks.
The first problem is related to column width... the phrase WHO IS ONLINE is too wide for the width you set. :roll:
The second problem is strange... it is working fine on my test site... :roll:
hm... it is strange because as you can see is shown bad only with IE, and if you look at the screenshot you will notice that Firefox has a default character bigger than IE, but it shows the block correctly...
Edit: of course! In IE character are more little so the width is more little too. Do you think that creating a shorter tbl_corner should help?
Is there anything I could check?
EDIT: I noticed that if logged in the only global block that works is the left column. No other block is shown.
PS: sorry for the last topic title you see in the last screenshot, I didn't notice that bad word. That is the BIN forum visible only to the admin :mrviolet:
If you press ctrl and zoom in or out with the mouse wheel you change the default text size, try restoring IE's to default
Generation Time: 0.1592s (PHP: 11% SQL: 89%)
