Post Limit Image Width Faster
The function limit image width actually gets the image width using a php function, and than (if the width passes the max image width set) it sets width="MAX_IMAGE_WIDTH" and the height proportionally, but this function can sometimes slow down the forum too much.
So this morning I was looking for a solution... and I managed to do it using javascript.
Maybe this can be raplaced with the actual limit image width function in the next xs release, I don't know how to replace, so for now I've just disabled the limit image width function and applied mine.
Here's what to do if you trust me :
Disable the limit image width function (ACP - General configuration - Image width, and set at least the first 2 options to NO)
OPEN
/templates/ca_aphrodite/overall_header.tpl
<script language="JavaScript" type="text/javascript" src="language/{L_BBCB_MG_LANG}/bbcb_mg.js"></script>
Before, ADD
function redimImg(foto, maxSize){
w = foto.width;
if (w > maxSize){
foto.width = maxSize;
</script>
OPEN
/templates/ca_aphrodite/bbcode.tpl
<!-- BEGIN img --><a href="{URL}"><img src="{URL}" border="0" alt="" /></a><!-- END img -->
<!-- BEGIN img --><a href="{URL}"><img src="{URL}" border="0" alt="" onload="redimImg(this, YOUR_MAX_IMAGE_WIDTH_VALUE);" /></a><!-- END img -->
<!-- BEGIN albumimg --><a href="album_showpage.php?pic_id={IMG_NUM}" target="_blank" class="postlink"><img src="album_thumbnail.php?pic_id={IMG_NUM}" alt="Image" title="Image" border="0" /></a><!-- END albumimg -->
<!-- BEGIN albumimg --><a href="album_showpage.php?pic_id={IMG_NUM}" target="_blank" class="postlink"><img src="album_thumbnail.php?pic_id={IMG_NUM}" alt="Image" title="Image" border="0" onload="redimImg(this, YOUR_MAX_IMAGE_WIDTH_VALUE);" /></a><!-- END albumimg -->
OPEN
/includes/bbcode.php
$html = '<img';
REPLACE WITH:
$html = '<img onload="redimImg(this, YOUR_MAX_IMAGE_WIDTH_VALUE);"';
OPEN
/album_mod/bbcode.php
$html = '<img';
REPLACE WITH:
Edited by KugeLSichA, Tue 29 Aug, 2006 23:08: added [codeblock] tags
AvrilBoiSend private messageVisit poster's website
Post Respuesta: Limit Image Width Faster
Can anyone confirm that this is working and that it is really faster?
Thanx!!!!
Icy Phoenix Latest 2.0 (working pending)
XusquiSend private messageVisit poster's website
Post Re: Limit Image Width Faster
Xusqui, I use it on my site (the link is in my profile), so you can check and can test posting a large image
Anyway it is faster because it uses a javascript and doesn't use php to get the images' widths and heights.
You can always open a topic in your forum with a large image, take trace of the page generation time, than make a backup of your files and apply my mod, and check the new page generation time;)
AvrilBoi, it's not the same using JS instead of PHP script for resizing images... try to load one big image, let's say 3MB, and then you will see that the image will be shown after some seconds !
Using that script the image is not resized... only the WIDTH will be set to a lower value, but the image will be loaded as full!!!
Using PHP instead, images will be recompressed on the server... so just another image will be loaded...
Try to believe!
I know that
Also the limit image width function does the same.
Try to believe!
Mighty, I think that there are 2 different options in xs... one that with php makes thumbnails and so a new smaller and compressed image is generated, and another, which is limit image width, which with php just sets width="max_im_width", and loads the full image just as my script does, with the difference that my script just uses javascript to resize the image after it has been loaded and showed fully, and the xs limit image width uses php.
... I can be wrong, so I'll re-test it on my site and I'll let you know
EDIT:
I've tested, and the limit image width function does load the full image and just sets width="MX_IM_WIDTH".
AvrilBoi wrote: [View Post]
EDIT:
Yes you're right about LIW... it doesn't actually resize images... it does set just the width.
Only Thumbs In Post will resize images creating a thumbnail!
Someone made me notice that it doesn't resize images in topic previews pages (posting.php?mode=topicreview&t=XXX)
So, if anyone is interested in making it work also there, here's what to do.
OPEN
/templates/ca_aphrodite/simple_header.tpl
<link rel="stylesheet" href="templates/ca_aphrodite/style_{TPL_COLOR}.css" type="text/css" />
After, ADD
w = foto.width;
if (w > maxSize){
</script>
