German Buttons For Morpheus IP
Subject: German Buttons For Morpheus IP
German Buttons for Morpheus IP
buttons-mo-ip.rar
Description: German Buttons for Morpheus IP
Filename: buttons-mo-ip.rar
Filesize: 232.41 KB
Downloaded: 288 Time(s)
Subject: Re: German Buttons For Morpheus IP
Wow, you did a great job... do you have a PSD for this set so we can use to create other languages?
Hi MG
I send you this as PM what i had
Pepi
Thanks pepi,
really great work. :mricy:
There is only one file wrong: icon_album
But no problem, MG has the psd... thanks for sharing it :mryellow:
@ TheSteffen
Here is the button icon_album :mricy: :mricy:
Pepi
// EDIT
Little mistake in buttons by FAP
Morphheus-IP-Buttons-German-Album.rar
Description: FAP
Filename: Morphheus-IP-Buttons-German-Album.rar
Filesize: 10.14 KB
Downloaded: 238 Time(s)
Thank you pepi, fracs is finishing the full PSD and the we will have a full one for translating all the langs.
If you need Triplex there is one free version and you can find it in Icy Phoenix package.
Off Topic
Your site really rocks... you have integrated Icy Phoenix in a wonderful way... my best compliments.
because of using Icy Phoenix with the gray morpheus template (available on phpbbstyles.com) I want to ask if you can change the german buttons into the gray layout...
Alternatively it would be great, if you can send me the psd-file...
thanx,
grisu
Could you please try the english butoons if they are OK for you?
Then I will greate german ones to :mricy:
By the way... I like the gray template.
Buttons_MorpheusIP_20080214_english.zip
Description: Buttons_MorpheusIP_20080214_english.zip
Filename: Buttons_MorpheusIP_20080214_english.zip
Filesize: 51.1 KB
Downloaded: 230 Time(s)
your gray buttons are perfect for my design.
It would be great, if you can modify them into german :LOL:
thanxy,
grisu
Give me some time... I will do it for you ;-)
Generation Time: 0.0854s (PHP: 22% SQL: 78%)
