SOLVED Could Not Insert Data Into Blocks Table
Subject: Could Not Insert Data Into Blocks Table
I get an error when creating a new block or existing a current one.
Could not insert data into blocks table
help whats wrong?
Subject: Re: Could Not Insert Data Into Blocks Table
can any one help me here?
I'm not getting this error. What versions of ip are u using? Upgrade to last version
Zuker wrote: [View Post]
it is the last version! could be some database error...what should i do? :cry:
Maybe you have too many blocks and in you database make sure the tables _cms_blocks, _cms_block_position and _block_variable are all there.
Everythings there mate....should i drop all cms tables and insert again?
This error is really strange... can you try to attach here in a zip file your blocks_table?
i dont know what u mean by blocks_table but i exported all phpbb_cms_xxx tables.
please have a look and tell me what to do!
web83-fidforum.sql.zip
Filename: web83-fidforum.sql.zip
Filesize: 5.75 KB
Downloaded: 166 Time(s)
Try to drop the cms tables and add them from scratch... maybe they are corrupted...
ok thanx!
solved
Great! :wink:
Generation Time: 0.246s (PHP: 8% SQL: 92%)
