Errorr During Installation
Subject: Errorr During Installation
errorr during installation of fresh installation of the last package
An error has occurred during installation
An error occurred trying to update the database
CREATE command denied to user 'semafor_xxx'@'xxx.xxx.xxx.xxx' for table 'ip_acronyms'
any one can tell me what i have made wrong ..
any help it will be aprecated
thanks
Subject: Re: Errorr During Installation
The user that u are using when installing do not have all the sql commands permissions
Set it to All, and you will have no problems
Generation Time: 0.1672s (PHP: 10% SQL: 90%)
