Topics/Posts count not increasing
Subject: Topics/Posts count not increasing
I can post, reply, move, delete, etc ..... but the Topics and Post columns are not increasing/decreasing the total count....at least not in any acceptable amount of time. Yesterday, I made 3 test post of new topics and 2 replys, but the columns' count did not appear until sometime today. :shock:
The Last Post column is updated immediately as expected.
Any ideas on why this is happening ?
This is on a home testing server and not a live site.
Subject: Re: Topics/Posts count not increasing
Artie wrote: [View Post]
Yes it is a bug which no one has raised yet... I have discovered it some days ago and solved.
But the solution isn't so easy... so I need to create a patch for that.
When I've finished playing with some other things, I'll create a full patch to solve this as well.
Thanks for noticing and raising it.
On top poster blocks it's the same thing, right?
Zuker wrote: [View Post]
Top Posters block should work fine... unless you are using an old version of Icy Phoenix... where that block was cached using old IM Portal functions.
i'm not having this issue, but some users @ phpbb-es.com told me that were having this kind of problem
Subject: Re: Topics/Posts Count Not Increasing
I have this problem in Top posters and topics and post columns. I see this in others forums IP.
Generation Time: 0.0765s (PHP: 34% SQL: 66%)
