Corporacion-Umbrella
 The Work Censor Don't Work
Hi.
In my forum, the word censor, don't work, i try several times, and nothing.
I have to change something?, or maybe is a bug?.
Thanks for your help.
#1 Sun 17 Jun, 2007 13:44 |
andrea75
 Re: The Work Censor Don't Work
Hi.
Check the preferences in your profile if the word censored are allowed or not.
____________ My Icy forum: www.lineameteo.it
#2 Sun 17 Jun, 2007 17:17 |
Thanks Andrea, but there are an anyway to config the censor word for all users?
For example not allow censored words for all users.
#3 Sun 17 Jun, 2007 18:36 |
There is a global switch in ACP... is it enabled?
#4 Wed 20 Jun, 2007 01:55 |
No MG, i can't see the option in ACP.
Where is it? for enable.
#5 Wed 20 Jun, 2007 07:12 |
mimoson999
I have the same problem.
I can't find the switch in the ACP
#6 Tue 26 Jun, 2007 22:22 |
I've tested it on my test site and Word Censor is working fine.
Add the words you want to censor and make sure that in your profile the Censor is enabled.
#7 Wed 27 Jun, 2007 02:22 |
mimoson999
the word censor work perfect, I'll never get tired of saying that Icy is great.
but you talk about a global switch on the ACP to force all users to use the word censor....I can't find that switch
#8 Wed 27 Jun, 2007 03:03 |
I added it in the past but then removed when Bicet added it for each user...
Sorry, it was my fault... I cannot remember all the active switches...
#9 Wed 27 Jun, 2007 03:12 |
Zuker
u can run this sql
UPDATE phpbb_users SET user_allowswearywords='1',
And after that, it can be set to default that field to 1
#10 Wed 27 Jun, 2007 04:04 |
Don't work that SQL Zuker, You konw why?
#11 Wed 27 Jun, 2007 07:33 |
Zuker
My mistake:P it must be an update, not an alter table
#12 Wed 27 Jun, 2007 13:35 |
mimoson999
but after the SQL the users can change it again to zero
it's going to be implemented in the next version to force the users?
#13 Wed 27 Jun, 2007 14:11 |
Zuker
i found this field inside config table
'global_disable_censor'
try to run dis sql
UPDATE phpbb_config SET global_disable_censor='1'
#14 Wed 27 Jun, 2007 14:33 |
mimoson999
UPDATE ip_config SET global_disable_censor='1'
don't work
I use this SQL
UPDATE ip_config SET `config_value` = '1' where `config_name`='global_disable_censor'
this SQL runs good but there is no change on the behavior of the word censor (only work when the user activates it)
#15 Wed 27 Jun, 2007 16:38 |
