I have done the upgrade xs 58 to Ip 1.1.0.15a and I see all the time a blank page.... www.tecno-mania.com
What I can do?
I have upgrade with the manual that is included in the IP folder:
Quote:Upgrade from phpBB XS
If you're using phpBB XS, you can upgrade your board by following these instructions (based on phpBB XS 058 standard setup):
1. Make a full backup of all files and database (if you don't do a backup, don't dare to ask for support! Backup Rules!)
2. Did you backup everything? If you didn't make the backup, please, step back to the previous point.
3. Copy your current .htaccess, config.php, includes/def_themes.php, includes/def_tree.php, includes/def_words.php and keep them in a safe place.
4. Check again that your backup is ok and keep it in a safe place. Backup Rules!
5. Login as administrator.
6. Lock your site.
7. Unpack Icy Phoenix package to one folder on your HD.
8. Upload and launch update_to_ip.php (which is in install folder) to the root of your phpBB XS (i.e. http://www.mysite.com/xs/update_to_ip.php). Please that if update_to_ip.php is not in the root of your phpBB XS, update it won't work correctly.
9. Delete update_to_ip.php.
10. Move the following folders:
* album_mod/upload/*.* ==> files/album/*.*
11. Remove the following folders (make sure you don't have in those folders some files you may need for some mods you have installed, but in any case you should have a backup Backup Rules!):
* adm
* album_mod
* attach_mod
* bb_usage_stats
* captcha
* ctracker
* db
* docs
* errors
* hl
* includes (all but includes/def_tree.php and includes/def_words.php)
* language
* mo
* mods
* stat_modules
* templates
* xs_mod
12. Remove all files but config.php in your phpBB XS root (make sure you don't have some files you may need for some mods you have installed, but in any case you should have a backup Backup Rules!).
13. Upload all Icy Phoenix files (all but config.php, includes/def_tree.php and includes/def_words.php) in the same folder where phpBB XS was installed and running. Pay attention that all older files eventually still there must be replaced by new ones.
14. Apply all permissions listed in Fresh Installation.
15. Customize what needs to be customized in files and db (some files needs to be edited manually, while most of the options may be set in ACP and CMS).
16. Unlock your site.
17. Enjoy your New Icy Phoenix Site Enjoy!.
Espa?a
BA
