Hello,
i m having a strange problem, even though i have changed the permission of the mentioned files to 777.
and when i proceed with the installation it displays me an error that the chmod is not set to 777.
can u suggest me a way, how to get rid of this problem....
waiting for the answers....
SOLVED Problem Even After Changing The Chmod
Subject: Re: Problem Even After Changing The Chmod
If you are sure that files are chmodded, click on start install anyway ;)
Thanks for the reply, i was able to install the board last night....
thanks to the developers for creating such a fantastic board
I had a similar error in RC3. (for the CHMOD 666)
Generation Time: 0.108s (PHP: 33% SQL: 67%)
