FAP CUSTOMIZATION - Member's Html Page?
Subject: FAP CUSTOMIZATION - Member's Html Page?
Hello. I'm not sure if this is the spot to post this, if so, please move it. I don't have a clue on coding things, so I'm asking you people who know a thing or two. I want my registered members to not only have a profile, but to also have a blank html page. So, they can build a little mini page off their profile. I want them to be able to edit it and upload things to a directory just for them. I want it to be like a little myspace for my members. Is this doable? And I also have a question about Icy that I can't seem to find an answer to anywhere. I want to change the font color of some of the elements, but I can't find the forum's template to change it.
My site url is: http://sims2news.com
My Icy's url is: http://sims2corner.com/s2nms/forum
Thanks! :wink:
Subject: Re: Member's Html Page?
I'm sure you could probably do something like that about their own little mini page but it might require a lot of work.
As for the text you would have to go into the template's CSS file to change the color.
Thanks! But, which CSS file? I've looked and looked, but cannot find a file that looks like ti contains any text colors.
Which template do you use?
Go to Templates>(whichever template you use)>CSS stylesheet or something.
All the files I have in the templates directory are:
Common (another directory)
mg_themes (another directory)
.htaccess
index.html
no theme or css file
Go into Mg_themes and open up your style css (there's 3 but make sure you pick the one your website is using)
Then just edit the text color codes to what you want. 8)
Yay, Found it! Thanks for your help! :wink:
Your welcome, if you need anything else don't be scared to ask. 8)
Generation Time: 0.1532s (PHP: 11% SQL: 89%)
