Post FireFox problems with local setup.
I really screwed something up
I don't know how it happened but now, on my local testing server, Firefox will not display any images/graphics associated with any site I load on the server for testing. Buttons, other theme images, album images, .... none appear.
All shows up fine on the WWW, just not locally.
At first I thought I had totally screwed up ICY, but then I tried using IE and it gave me no problems at all.
I open for suggestions on what I might look for.... anyone have any ?
ArtieSend private message
Post Re: FireFox Problems With Local Setup.
Artie wrote: [View Post]
Have you got installed adblock?
If you have, see that you haven“t got your local webpage into the blacklist. For adding any web to the whitelist, put
@@www.[color=red][size=14]the-web-you want[/size][/color].[color=red][size=14]domain[/size][/color]
I mean, put the double @@ before the webpage.
Post Re: FireFox problems with local setup.
Thank you so much
  I have no idea how that happened, but that was the problem.
Thanks again
