Post Gallery Mod
Gallery2 phpBB2 Integration Pack - zip file  Popular
Description: The integration package required to integration G2 in to phpBB2.
http://www.nukedgallery.net/download-file-49.html
http://gallery.menalto.com/
Gallery is awesome...it can be integrated into phpbb...
the FAP here isnt that good as compared to gallery2.
So can any one see if gallery is compatible with IP?
also how to disable FAP in ICY??
toledoSend private message
Post Re: Gallery Mod
I hope you are wearing flame retardant clothing.
ArtieSend private message
Well.....anyone got answers?
Off Topic
 Artie: [View Post]
i'm with artie
call 911
whoa whoa....hold on mates...
instead of telling all that.....can anyone be kind enough to tell what is wrong in asking for support here???
toledo wrote: [View Post]
If Gallery is compatible with phpBB then it is compatible with Icy Phoenix as well... but it needs to be readapted for Icy Phoenix files structure and BBCodes.
I won't do that for you of course... maybe someone else is interested and may help you.
To disable FAP just go in CMS Page Permission and give access only to admins for the album.
thanx mighty...for clearing up the confusion and doubt.
hey u others...this is the way you should reply!
