Yep... It works... I got it working until I updated to 058... I will re-install it again along the weekend!!
I used to use de Medal System Mod 0.46. The only bad thing about this mod is that increases the querys to the db too much!!! 30 or so per post without the mod, 60 or so with the mod...
____________ Icy Phoenix Latest 2.0 (working pending)
You create medals for your website and you reward your users with them...
IE: You create a game in your web, for example a trivial, after it finish, you reward the winner with a medal that will be shown in the forum!!
No... It's displayed as a single image anywhere you want...
Sometimes I had it displayed under the avatar, somtimes on the signature, sometimes at the right of the text of the post... Depending on de template!
The time now is Mon 04 Aug, 2025 19:25 • All times are UTC + 1 Hour [DST enabled]
