Post Pando Bbcode For Icy Phoenix
20080108104344xh1
20070812134133kv2
V2.0
-fix the problem when signature is enable
## MOD Title: pando bbcode para ice phoenyx
## MOD Author: robincracker http://www.mercado-negro.org.org
## MOD Description: pando bbcode
## MOD Version: 1.0.0
## Installation Level: Easy
## Installation Time: 5 minutes
## Files To Edit: includes/bbcode.php
##                language/lang_XXXX/bbcb_mg.js
##                templates/mg_themes/bbcb_mg.tpl
## Included Files:
##                images/bbcb_mg/images/gif/pando.gif
##                images/bbcb_mg/images/gif/pando1.gif
##                pando/pando.cs
##                pando/pando_script_mn.js
##                  pando/pandoAPI.js
##                  pando/cajamn.gif
## License: http://opensource.org/licenses/GPL-license.php GNU General Public License v2
## Before Adding This MOD To Your Forum, You Should Back Up All Files Related To This MOD
#----[COPY]----
images/bbcb_mg/images/gif/pando1.png to images/bbcb_mg/images/gif/pando1.png
images/bbcb_mg/images/gif/pando.png to images/bbcb_mg/images/gif/pando.png
pando/pandoAPI.js     to pando/pandoAPI.js
pando/pando_script_mn.js to pando/pando_script_mn.js
pando/cajamn.gif to pando/cajamn.gif
pando/pando.css     to pando/pando.css
#----[OPEN]----
includes/bbcode.php
#----[FIND]----
            'youtube' => array(
                    'nested' => true,
                    'inurl' => true,
                    'allow_empty' => false,
#----[AFTER ADD]----
            'pando' => array(
                    'nested' => true,
                    'inurl' => true,
#----[FIND]----
            // FLASH, SWF, VIDEO, REAL, QUICK, STREAM, EMFF, YOUTUBE, GOOGLEVIDEO
, PANDO
#----[FIND]----
                        if( ($tag === 'flash') || ($tag === 'swf') || ($tag === 'video') || ($tag === 'ram') || ($tag === 'quick') || ($tag === 'stream') || ($tag === 'emff') || ($tag === 'mp3') || ($tag === 'youtube'
 || $tag === 'pando'
#----[FIND]----
                elseif ($tag === 'youtube')
                    $html = '<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/' . $content . '" /><embed src="http://www.youtube.com/v/' . $content . '" type="application/x-shockwave-flash" width="425" height="350"></embed></object><br /><a href="http://youtube.com/watch?v=' . $content . '" target="_blank">Link</a><br />';
#CAMBIAR ,TU URL, POR LA URL DEL FORO
                elseif ($tag === 'pando')
                    $html = '<LINK REL=STYLESHEET TYPE="text/css" HREF="TUURL/pando/pando.css" >
                        <script src="TUURL/pando/PandoAPI.js" type="text/javascript"></script>
                        <script src="TUURL/pando/pando_script_mn.js" type="text/javascript"></script>
                        <script>showPackage("' . $content . '");</script>';
#----[OPEN]----
#----[FIND]----
s_ram_insert =
s_pando_insert = 'Por favor ingrese el IM link del pando';
s_pando_insert_tip = 'pando IM';
#----[FIND]----
s_flash_h_error =
s_pando_insert_error = 'No haz ingresado el IM link';
#----[FIND]----
s_marqd_help =
s_pando_help = 'Ingrese el IM link: [pando]pandoIM link[/pando]';
#----[FIND]----
'[wave]','[/wave]',
'[pando]','[/pando]',
#----[FIND]----
function BBCram()
    var FoundErrors = '';
    var enterURL = prompt(s_ram_insert ,s_url_insert_tip);
    if (!enterURL)
        FoundErrors += s_file_insert_error;
    if (FoundErrors)
        alert(s_gen_error + FoundErrors);
        return;
    var ToAdd = "[ram]"+enterURL+"[/ram]";
    PostWrite(ToAdd);
function BBCpando()
    var enterURL = prompt(s_pando_insert, s_pando_insert_tip);
    if (!enterURL)
        FoundErrors += s_pando_insert_error;
    if (FoundErrors)
        return;
    var ToAdd = "[pando]"+enterURL+"[/pando]";
    PostWrite(ToAdd);
#----[OPEN]----
#----[FIND]----
                            <a href="javascript:BBCflash()"><img border="0" src="{BBCB_MG_IMG_PATH}flash{BBCB_MG_IMG_EXT}" name="flash" type="image" onMouseOver="helpline('flash')" alt="L_BBCB_MG_FLSH}" title="{L_BBCB_MG_FLSH}" class="bbimages" /></a>
                            <a href="javascript:BBCpando()"><img border="0" src="{BBCB_MG_IMG_PATH}pando{BBCB_MG_IMG_EXT}" name="pando" type="image" onMouseOver="helpline('pando')" alt="pando" title="pando" class="bbimages" /></a>
#----[END]----
hello i searh in google but don  find any to add a custom bbcode in phoenix and button to appear in post like youtube  , anyone can tell me how to do this thanks
enjoy it
Support spanish and for othr cms
http://www.toppando.mercado-negro.o...id=1&pid=1#pid1
icybbcode 2.01.zip
Description: pando bbcode icyphoenyx 2.01
Filename: icybbcode 2.01.zip
Filesize: 21.98 KB
Downloaded: 292 Time(s)
robin crackerSend private messageVisit poster's website
Post Re: How To Add A Custom Bbcode And Button
robin cracker,
witch bbcode u want to be inside posting as a button?
Zuker wrote: [View Post]
robin cracker,
well is this code
<LINK REL=STYLESHEET TYPE="text/css" HREF="Turl/pando.css" >
                <script src="url/PandoAPI.js" type="text/javascript"></script>
                <script src="Turl/pando_script_mn.js" type="text/javascript"></script>
                <script>showPackage(">                 <script>showPackage("$1");</script><");</script>
to show a box  like
20070808134216dz7
the files pando api, pando script and pando.css is in the zip is amod to smf but work with other forums but i dont know how add a bbcode in phoenix
pando bbcode final.zip
Filename: pando bbcode final.zip
Filesize: 42.92 KB
Downloaded: 316 Time(s)
no em habia percatado que tenias la bandera de argentina, veras es que lo qu deseo es agregar un bbcode que trabaje usando lsos cript que adjunte arriba, pero no se que archivos debo modificar para agregar ese codigo y al usar la etiqueta muestre el resultado como se ve en la magen
Try to play with bbcode.php, bbcb_mg.tpl and bbcode.js
solve it thaks download the goear bbcode and modify to my bbcode,
20070812134044qd4
20070812134133kv2
attacht the pandobbcode
## Included Files:
##                pando/pando.cs
##                  pando/cajamn.gif
#----[COPY]----
#----[OPEN]----
includes/bbcode.php
#----[FIND]----
            'youtube' => array(
                    'nested' => true,
                    'inurl' => true,
            'pando' => array(
                    'nested' => true,
                    'inurl' => true,
#----[FIND]----
, PANDO
#----[FIND]----
 || $tag === 'pando'
#----[FIND]----
#----[OPEN]----
#----[FIND]----
s_ram_insert =
#----[FIND]----
s_flash_h_error =
#----[FIND]----
s_marqd_help =
#----[FIND]----
'[wave]','[/wave]',
#----[FIND]----
function BBCram()
    if (!enterURL)
    if (FoundErrors)
        return;
    PostWrite(ToAdd);
function BBCpando()
    if (!enterURL)
    if (FoundErrors)
        return;
    PostWrite(ToAdd);
#----[OPEN]----
#----[FIND]----
#----[END]----
ice phoenyx pando bbcode.zip
Filename: ice phoenyx pando bbcode.zip
Filesize: 42.82 KB
Downloaded: 291 Time(s)
great
moved to customizations
Hi!
This mod post by "robin cracker" also works to make a HIDE BBCode button?
leonidfgSend private message
Post Re: Pando bbcode For Icy Phoenix
leonidfg wrote: [View Post]
Hi!
what do you mean by "works to make a hide bbcode"?
Hi!
maybe this part
#----[OPEN]----
#----[FIND]----
#----[END]----
try  replace pando by hide
a little error
 || $tag === 'pando'
is
 || ($tag === 'pando' ) )
Desing
KtmDesingz
[spoiler][img]http://i116.photobucket.com/albums/o37/_ktm_/Firma32.jpg[/img][/spoiler]
-ktm-Send private messageVisit poster's website
another problem
check http://ktmdesignz.com/forum/viewtopic.php?t=3768
Desing
KtmDesingz
Post Re: Pando Bbcode For Icy Phoenix
es correcto hay algunos detalls por corregir, desafortunadamente  ando orto de tiempo, revisare el script haber si hay algo que hay que cambiar
robin cracker wrote: [View Post]
check this topic
http://www.eddb.com.ar/viewtopic.php?p=31695#p31695 (second page)
it's fine there, right? i think i 've fixed it
great . how do you do?
