Post Calendar Does Not Appeard
In the administration panel I have it activated, but it does not appear in the forum. Only I can put it like a block in the portal, but I want it in the forum. Some way to ahcer that it appears in the forum?
fran_o8Send private message
Post Re: Calendar Does Not Appeard
inside overall_header
find
    <a href="javascript:ShowHide('news','news2','news');" title="{L_SHOW} {NEWS_TITLE}"><img src="{IMG_NAV_MENU_NEWSPAPER}" alt="{L_SHOW} {NEWS_TITLE}" /></a>&nbsp;
    <a href="javascript:ShowHide('quick_links','quick_links2','quick_links');" title="{L_SHOW} {L_QUICK_LINKS}"><img src="{IMG_NAV_MENU_APPLICATION}" alt="{L_SHOW} {L_QUICK_LINKS}" /></a>&nbsp;
    <a href="javascript:ShowHide('calendar_display','calendar_open_close','quick_links');" title="{L_SHOW} {L_CALENDAR}"><img src="{IMG_CALENDAR}" alt="{L_SHOW} {L_CALENDAR}" /></a>
replace with
They are not the lines that your you say to find Zuker
What theme are u using?
Milky Way (default) and Icy Phoenix
attach your header, that lines should be there
As the format .tpl I cannot upload it, I leave to another Web so that it to you downloads and you verify that they are not those lines.
http://www.filefactory.com/file/0b36a9/
fran_o8 wrote: [View Post]
attach it here as .rar or .zip
Here is the overall_header
overall_header.rar
Filename: overall_header.rar
Filesize: 2.56 KB
Downloaded: 202 Time(s)
please search again, that lines are in your file.
search after
  1. <!-- END ctracker_message -->
  2.
  3. <tr>
  4.     <td colspan="3" id="content">
Zuker, they are not those lines
From line 172 to line 176. THEY ARE THERE
Well, already I have replaced the lines. But now in index of forum it gives the option to show calendar, does not show it automatically. But when I give to show to forum not suce him nothing. It does not appear nor it passes anything.
Image: http://i10.tinypic.com/6bd584p.jpg
an url to see it in action?
Zuker wrote: [View Post]
Does not appeard in the forum. I click on "Mostrar Calendar" but not appeard
Post new topic  This topic is locked: you cannot edit posts or make replies.  Page 1 of 2
