Post Table BBCode
There are a bbcode to Icyphoenix to add tables in my forum?
Thanks!
carmelomvpSend private message
Post Re: Table BBCode
You can enable them by enabling html, add table tags in allowed tags in ACP end edit bbcode.php.
Otherwise you may use these classes:
http://www.icyphoenix.com/viewtopic.php?t=1758
Or you can create CMS blocks using pure HTML.
Ok how can i do this?I know how enable the html but how can i add the html in the bbcode.php?
Thanks!
search for the table tags in bbcode.php and decoment them
for ex.
  1.             /*
  2.             'table' => array(
  3.                     'nested' => true,
  4.                     'inurl' => true,
  5.                     'allow_empty' => false,
  6.                     ),
  7.             */
  8.             /*
  9.             'tr' => array(
  10.                     'nested' => true,
  11.                     'inurl' => true,
  12.                     'allow_empty' => false,
  13.                     ),
  14.             'td' => array(
  15.                     'nested' => true,
  16.                     'inurl' => true,
  17.                     'allow_empty' => false,
  18.                     ),
  19.             */
should be
  1.             'table' => array(
  2.                     'nested' => true,
  3.                     'inurl' => true,
  4.                     'allow_empty' => false,
  5.                     ),
  6.             'tr' => array(
  7.                     'nested' => true,
  8.                     'inurl' => true,
  9.                     'allow_empty' => false,
  10.                     ),
  11.             'td' => array(
  12.                     'nested' => true,
  13.                     'inurl' => true,
  14.                     'allow_empty' => false,
  15.                     ),
Search for TABLE, TR AND TD
