Post Table COLOR_GROUPS_TABLE?
In ACP to colors are this error:
Error general
Error de búsqueda en la tabla de Usuarios.
DEBUG MODE
SQL Error : 1146 Table 'kokforos_db.COLOR_GROUPS_TABLE' doesn't exist
SELECT group_id, group_name FROM COLOR_GROUPS_TABLE
Line : 150
File : admin_color_groups.php
In de backup od the database not are this table
What is the estructucture of teh this table?
? JHOSMAN - Webmaster
JHOSMANSend private messageVisit poster's website
Post Re: Table COLOR_GROUPS_TABLE?
That table does not exists any more i think. Users are colored by users table
When upgrading. delete all files that are not needed anymore
Zuker wrote: [View Post]
In the FTP and DD the file admin_color_groups.php  are not exist
You are doing updating progress wrong. chek all the steps carefully
It's not "upload & run"
JHOSMAN wrote: [View Post]
Error general
DEBUG MODE
Line : 150
Delete ACP folder... the file that have this error not exist in the new IP beta.
I hope you can understand me
labelinaSend private message
labelina wrote: [View Post]
Error general
DEBUG MODE
Line : 150
The problem is solved... The color od the groups are asigned manual
All users is a one color the problem are not solved...
Becase you didn't set any color for nicknames/groups.
All groups are asigned a color, the problem are no solved
KTM got the same problem, it was because of a bad upgrade procedure. Check it again.
Try to set an individual color to a user and see if it appear
