Last 10 Topics Mod
Subject: Last 10 Topics Mod
I'm using Black Pearl style on phpBB 3 RC5 and would like to ask if there is a "last 10 topics" mod or something like that.
Subject: Re: Last 10 Topics Mod
No, but you can easily adapt it to Black Pearl.
Hi MG,
thanks for your reply. :king: I couldn't see your reply in time because the check box about notifying was unchecked in this topic for some reason. I made a search for a "recent topics" mod again a moment ago and came across my own topic.. :oops: Can I find something like that here to adapt to Black Pearl? I searched the phpBB 3 MODS And Styles section but couldn't find anything like that.
Thanks again.. smile (p.s. this smiley has the same code with this one smile )
Regarding your support request, I would say you may use the subSilver 2 template with a small modification... you can open FAQ tpl to see the difference between subSilver 2 and Black Pearl... you will notice that only few modifications has to be applied.
Try on your own and then report the results... if you succeed you will be able to do it on your own in the future. :mri:
Regarding the smiley, I have 0002 : 0002 : (with no spaces) for that smiley... which code are you looking at? :shock:
So you mean that there is something like that in the original subSilver.. OK then I will try to figure it out and report the result. :) (BTW I really would love to have a smiley in this forum like this :king: without the crown :) )
As for the smiling smileys, when I click on 0002 in the smileys window it appears in the text like this
  1. :smile:
and in the post like this smile
Generation Time: 0.0836s (PHP: 21% SQL: 79%)
