015-0019 Bug In Ctraker .htaccess File
Subject: 015-0019 Bug In Ctraker .htaccess File
This bug is also in the beta!!
Problem description:
When you get to the ctraker logs in ACP, you get a high number of logs entries, but when get to file it appears a white page. If you try to get with the browser to that file, you will find a non-authorizated error message.
SOLUTION:
The debug mode of Ctraker isn´t allowed to get to the log file when needed because:
  • Htaccess doesn´t allow that
This is caused because:
in /ctracker/logfiles/.htaccess the text is:
<Limit GET POST PUT>
Order Allow,Deny
Deny from All
Allow from localhost 127.0.0.1
</Limit>
So the server thinks the url allowed is "http://localhost%20127.0.0.1" and rest are :censored:
This is solved by setting a ',' in this line:
So it results in:
  1. Allow from localhost, 127.0.0.1
So it will allow the adresses "localhost" and "127.0.0.1"
Unless you do this, the log will show a lot of entries on the ACP and when get to the file, it won´t show anything, `cause there is nothing written on it.
Last edited by novice programmer on Tue 16 Oct, 2007 16:35; edited 2 times in total
Subject: Re: Bug In Ctraker .htaccess File
In that file the text is:
Order Allow,Deny
Deny from All
</Limit>
And the file set the secuence:
  1. Order Allow, Deny
and it´s rutine is:
First, disallow all
Then, allow localhost
So, it has to be (too):
Order Deny, Allow
Deny from All
</Limit>
So you will set the first orders are going to set a deny condition and the second ones are going to set an allow condition.
Subject: Re: 015-0019 Bug In Ctraker .htaccess File
Topic locked as bug solution explained.
Topic moved to bugs section and changed topic title properly.
I have totally recoded this for next version... so htaccess should work fine.
Thanks. :mricy:
Generation Time: 0.1244s (PHP: 13% SQL: 87%)
