FAP SUPPORT - [solved] Error With New Install
Subject: FAP SUPPORT - [solved] Error With New Install
Dear all,
New user and install of FAP 1.4.1 here.
Upgrading from Smartor's Album...and have problems with accessing even the ACP part of it all.
Would be very grateful if somone can offer any hints of where my eror lies on this.
A "simple" path problem? I noticed there are path settings in Album.php and I tried editing those...
My forum is in the root of our webhotelspace.
My suspicion is also with the /cgi-bin/ directory and how that is referenced from the sql base.
The phpmyadmin panel says "/cgi-bin/"
Should it be something else if my forums are in the root of the webhotel? "../cgi-bin/" "/.cgi-bin/"
Should that directory be in the root?
TIA and best regards
Janne A.
Here is my error when trying the configuration link in ACP
Warning: main() [function.main]: Unable to access ../ALBUM_MOD_PATHalbum_hierarchy_debug.php in /customers/afff.se/afff.se/httpd.www/admin/admin_album_config_extended.php on line 66
Warning: main(../ALBUM_MOD_PATHalbum_hierarchy_debug.php) [function.main]: failed to open stream: No such file or directory in /customers/afff.se/afff.se/httpd.www/admin/admin_album_config_extended.php on line 66
Here is the error when surfing to the album as end user.
Warning: main(ALBUM_MOD_PATHalbum_common.php) [function.main]: failed to open stream: No such file or directory in /customers/afff.se/afff.se/httpd.www/album.php on line 61
Warning: main() [function.include]: Failed opening 'ALBUM_MOD_PATHalbum_common.php' for inclusion (include_path='m2f/includes/pear/:../m2f/includes/pear/:.:/usr/lib/php') in /customers/afff.se/afff.se/httpd.www/album.php on line 61
Fatal error: Call to undefined function: album_read_tree() in /customers/afff.se/afff.se/httpd.www/album.php on line 135
Subject: [deleted]
deleted by me
Subject: Re: Error With New Install
Check that you did this part of the install
#-----[ OPEN ]------------------------------------------------
includes/constants.php
#-----[ FIND ]------------------------------------------------
if ( !defined('IN_PHPBB') )
die("Hacking attempt");
#-----[ AFTER, ADD ]------------------------------------------
// Mighty Gorgon - Full Album Pack - BEGIN
define('ALBUM_MOD_PATH', 'album_mod/');
define('ALBUM_FILES_PATH', 'album_mod/upload/');
include($phpbb_root_path . ALBUM_MOD_PATH . 'album_constants.' . $phpEx);
// Mighty Gorgon - Full Album Pack - END
Thanx so much for reply!
MAn you're quick..
Yes I had missed that part,
Thanx again!
Janne A.
Generation Time: 0.9629s (PHP: 2% SQL: 98%)
