Post Problem With Themes And Explorers
then I have a small problem and not if it is possible to be solved somehow.
the problem is that when open my page with IE it sees asi:
I abro perosi it with mozilla is seen well.
some idea, thank you very much
kenetSend private message
Post Re: Problem With Themes And Explorers
hi,
on my site it is the same. with firefox and opera it works great but with ie6/7 only the blockheader is so wide if the text is "long". i`m not sure but i think it`s since the last ie-update. can it be? can somebody help please?
storyteller
StorytellerSend private message
they have said to me that there is to publish this file, I publish but it I raise, it with the FTP but it does not change anything to me.
kenet wrote: [View Post]
url autourl-1772185670 nofollow-1-
asi = just like this
abrir = open/go to (depende del contexto)
pero = but
si = if
I can only open it with mozilla. IE7 gets crashed when I get into a icy phoenix forum.
hmm, asi-abrir-pero-si
not English, use a translator
sorry, but for me it wasn`t clear that this is only a translation! now i get it!
