Floating Bar On Ip ?
Subject: Floating Bar On Ip ?
hi everyone sorry for my english
i want to put this code on my ip but i cant do it for guest only
i put this code on footer by my ACP
if somebody can help me i will thank
<head> code:
<head>
<style type="text/css">
#topbar{
position:absolute;
border: 1px solid black;
padding: 2px;
background-color: lightyellow;
width: 620px;
visibility: hidden;
z-index: 100;
</style>
var persistclose=0 //set to 0 or 1. 1 means once the bar is manually closed, it will remain closed for browser session
var startX = 30 //set x offset of bar in pixels
var startY = 5 //set y offset of bar in pixels
var verticalpos="fromtop" //enter "fromtop" or "frombottom"
function iecompattest(){
return (document.compatMode && document.compatMode!="BackCompat")? document.documentElement : document.body
function get_cookie(Name) {
var search = Name + "="
var returnvalue = "";
if (document.cookie.length > 0) {
offset = document.cookie.indexOf(search)
if (offset != -1) {
offset += search.length
end = document.cookie.indexOf(";", offset);
if (end == -1) end = document.cookie.length;
returnvalue=unescape(document.cookie.substring(offset, end))
return returnvalue;
function closebar(){
if (persistclose)
document.cookie="remainclosed=1"
document.getElementById("topbar").style.visibility="hidden"
function staticbar(){
barheight=document.getElementById("topbar").offsetHeight
var ns = (navigator.appName.indexOf("Netscape") != -1) || window.opera;
var d = document;
function ml(id){
var el=d.getElementById(id);
if (!persistclose || persistclose && get_cookie("remainclosed")=="")
el.style.visibility="visible"
if(d.layers)el.style=el;
el.sP=function(x,y){this.style.left=x+"px";this.style.top=y+"px";};
el.x = startX;
if (verticalpos=="fromtop")
el.y = startY;
else{
el.y = ns ? pageYOffset + innerHeight : iecompattest().scrollTop + iecompattest().clientHeight;
el.y -= startY;
return el;
window.stayTopLeft=function(){
if (verticalpos=="fromtop"){
var pY = ns ? pageYOffset : iecompattest().scrollTop;
ftlObj.y += (pY + startY - ftlObj.y)/8;
else{
var pY = ns ? pageYOffset + innerHeight - barheight: iecompattest().scrollTop + iecompattest().clientHeight - barheight;
ftlObj.y += (pY - startY - ftlObj.y)/8;
ftlObj.sP(ftlObj.x, ftlObj.y);
setTimeout("stayTopLeft()", 10);
ftlObj = ml("topbar");
stayTopLeft();
if (window.addEventListener)
window.addEventListener("load", staticbar, false)
else if (window.attachEvent)
window.attachEvent("onload", staticbar)
else if (document.getElementById)
window.onload=staticbar
</script>
</head>
<body> code:
<body>
<div id="topbar">
<a href="" onClick="closebar(); return false"><img src="close.gif" border="0" /></a>
<a href="h**p://***.forotupc.com/tupc/profile.php?mode=register"><img
style="border: 0px solid ; width: 300px; height: 90px;" alt=""
src="h**p://***.forotupc.com/tupc/otros/registrate.jpg"></a>
[color=deepskyblue]</body>[/color]
close.gif = h**p://***.forotupc.com/tupc/otros/close.gif
my text to edit is:
what can i do???????????
my forum:
Subject: Re: Floating Bar On Ip ?
Zuker has done something like that, so you can try to ask him.
Not help guaranteed.
ok...thanks
Zuker i hope that you can help me
i dont ask on phpbb-es because nobody answer my questions
:D
nobody???
fapro wrote: [View Post]
nobody???
Try to write to him by PM
Generation Time: 0.1594s (PHP: 11% SQL: 89%)
