Post 1.1.0.15d / 1.1.7.22a RC1 - Extra Patch
Hi all,
unfortunately I have to release another security patch for both versions.
This will solve a RFI issues in some blocks for those servers who don't have register_globals set to OFF.
To install this patch you have to delete entirely your stats_modules folder and reupload the attached files.
Instructions for both 1.1.0.15 and 1.1.7.22 RC1 versions:
  • Download the attachment here and decompress it.
  • Open your includes/stat_modules/ folder and delete everything is into it.
  • Upload the content of the attachment.
Update your sites as soon as possible please.
ip_stat_modules_20071220.zip
Description: IP Stat Modules Patched
Filename: ip_stat_modules_20071220.zip
Filesize: 81.92 KB
Downloaded: 791 Time(s)
