I am having a real problem with Black Pearl.
When I try to upload an avatar, I get the following message: "The submitted form was invalid. Try submitting again."
Unfortunately, I had the very same problem (using Black Pearl) trying to log into the ACP and since I could not get to the ACP, I could not change the style and I was stuck. I dumped everything, reloaded phpBB3 (it was running great) and then added Black Pearl again. It seemed to be working ok but I was already logged into the ACP on another window and never left that so I am still in control. I'm afraid if I log out of the ACP without changing back to subsilver then I will be messed up again.
Any idea why I would be getting this error?
Any help is MUCH appreciated!
I wish to amend part of my statement...
When I try to log in to the ACP using Black Pearl I get the following error:
You need to enter your password to access the Administration Control Panel.
Well... I have entered it every time and it continues to act as if I didn't.
The avatar deal is still giving me the other message I mentioned in the previous post.
By the way.... I'm now locked out of the ACP again as my login expired. Looks like another complete start over unless I can find a solution to this.
Help!
Black Pearl Problem (The Submitted Form Was Invalid...)
Subject: Black Pearl Problem (The Submitted Form Was Invalid...)
Subject:
Please delete this post... thank you.
Subject: Re: Black Pearl Problem (The Submitted Form Was Invalid...)
Are you sure you are running the latest version of the template with the latest version of phpBB?
Since RC5 phpBB team added forms TOKEN to validate submission. If you are not running the latest versions you may have problems.
Thank you MG... I was using the wrong version as you suggested. It is now fixed and you are a code guru if I ever saw one! Just Fantastic! :mrorange:
Generation Time: 0.2051s (PHP: 9% SQL: 91%)
