Post Details, Viewerlist?
Subject: Post Details, Viewerlist?
is it possible after pushing the post details button, to show the usernames instead of the User IPs?
Subject: Re: Post Details, Viewerlist?
Yes, but you should change PHP files and TPL as well to achieve this.
Why you don't want IP to be shown? I guess only admins and mods may view it.
why? hehehe, i wanna punish them whom dont reply on on our topics!
tell me please how iam doin it? which codes/files must i add/change?
Tell me exact phpBB 3 links where you want to put that and when I have some freetime I will try to check.
as example what i wanna mean and wanna do is
after opening a topic
Forum/viewtopic.php
and pushing after the topic details buttons
this window opens
Forum/MCP.php?i=main&mode=post_details
and of the bottom of this page ist possible to view the ips of users whom opened this topic
i would like to know how replace the ips with the usernames? or is it possible?
Forum/viewtopic.php
this window opens
Generation Time: 1.3204s (PHP: 1% SQL: 99%)
