Hi Everyone
When you are using the moderator tool for FAP and you remove pictures from the gallery, does this remove it from the DB and off the server? If it is just from the DB how do you remove the particular file when in my case it could be hundreds of pics?
I recently just deleted some pics from the gallery via the server (manually) and now I get blank thumbnails for those pics deleted which make sense. Is there a way to find all the files that were just deleted so I can quicken the removal process?
I know someone gave me a mod once to add thumbnails to the moderator view so you can view what you are deleting. Is there also a mod to show all pics in just one view so I can scroll down them all in one view and not go page by page?
-D1-
FAP SUPPORT - Deleted Images And The Database
Subject: Re: Deleted Images And The Database
Anyone have the answer to at least the first question? Please :)
Generation Time: 0.1572s (PHP: 10% SQL: 90%)
