Statistics Not Updated!
Subject: Statistics Not Updated!
Hi guys,
the new year brought to my forum a new problem.
The list of users that visited the forum in the current day is not being updated since December 31th.
It keeps showing the list of that day to guest and users, but as admin I can see the correct list.
I can’t understand if it is a bug, do others have the same problem? And how to fix it?
Thank you for your support!
Subject: Re: Statistics Not Updated!
I think there is a global error since december 31st. :P
Gianni PB wrote: [View Post]
Yeah, the Year 20008 Problem :LOL:
clear cache and solved :-)
It was not enough to clean the cache, I had to manually remove the files last_visit_x_x_xx.dat to solve the problem. Now is everything ok. Well, not exactly everything, but almost :wink:
Generation Time: 0.5414s (PHP: 3% SQL: 97%)
