Bug In Quick Links Table In Index.php
Subject: Bug In Quick Links Table In Index.php
Hello there,
I suggest to check the proper design of the table "quick links" in home page, because if a photo in the lower box is larger than it, it's badly displayed.
Now I'm checking what I can in these days, 'cause it should be useful for the last version of XS2, 059, if Mighty Gorgon or someone else is working on it.
Best regards.
Subject: Re: Bug In Quick Links Table In Index.php
you can change thumbnail size in ACP or you want big photos :D
what is your browser ?
difus wrote: [View Post]
Firefox and Safari
yours is not a fix!
It depends even on your album thumbnails settings... :roll:
For the moment, move the PHOTO blocks on the other side of the portal! :LOL:
Generation Time: 0.1622s (PHP: 11% SQL: 89%)
