When I go to the ACP and I check "Yes" for Disable public blacklist IP check upon register and Submit ... the option NO is still checked i can't change it to YES.
Saludos
Now, a new problem, I have 4 mini banners and for some reason doesn't show on Index (near footer) and they're active but still not appearing ...... Link
PS.: emoticons on quick reply ... sweeeeeeeeeeeeeettttttt
4 links with images, the 4 liks are ON, the URL for the images are (example): images/links/image.gif
Note: I Have too many problems with phpBBXS (049), the new forum I installed is a copy (downloaded from phpBBXS.com) without the patches, because phpBBXS.com is down. Anyone have a phpBBXS 049 patched? original copy.
The time now is Thu 19 Mar, 2026 17:27 • All times are UTC + 1 Hour
