Re: Critical Error
it is your root/templates/mg_themes
this mg_themes can be also ca_aphrodite or another , depend of theme u are using
so this .css is in template/your thema folder...
see pic maybe can help you....
The time now is Sun 18 Jan, 2026 18:27 • All times are UTC + 1 Hour
