GlosterMan
 Shoutbox For PHPBB3?
Is the shoutbox used on this website available for PHPBB3 or is it an Icy Phoenix Mod?
I was going to use the Shoutbox/Chat from STG but I found out is shows hidden members
Any help on what the best chat/Shout box is for PHPBB3?
#1 Mon 25 Feb, 2008 03:20 |
 Re: Shoutbox For PHPBB3?
All stuffs you see on this site have been coded (or recoded where I didn't like original mods) for Icy Phoenix which is NOT based on phpBB 3.
Regarding other Shoutbox, Chat system, unfortunately I didn't test any of the existing mods, so I cannot help.
#2 Mon 25 Feb, 2008 09:55 |
Huor
I have a shoutbox running from AJAX on a phpBB3 forum. I also adapted the black pearl style to it.
You can have a look at trf.mc-sig.de at the very bottom of this side. The only disadvantage until now: The messages disappaer after a timeperiod (can be setup i guess^^).
If you want more detail - pls let me know
Greez...
#3 Mon 25 Feb, 2008 20:23 |
ThE KuKa
#4 Mon 25 Feb, 2008 22:07 |
It would be great if you share shoutbox template files for other users who may need them.
#5 Tue 26 Feb, 2008 00:31 |
Huor
Well as i don't know really where to post this. I insert it here
The following changes can be done to include the AJAX-Shoutbox to the bottom of your PHPBB3 forum.
Look at the following steps.
BTW you should consider the installation steps to integrate the AJAX Shoutbox to your forum -> click here.
This should be done before the following changes of Black Pearl Template...
OPEN <phpBB3 dir>/styles/black_pearl/template/overall_footer.html
<div style="text-align:center;">
<!-- IF U_ACP -->
<br />
<br />
<span class="gensmall">
[ <a href="{U_ACP}">{L_ACP}</a> ]
</span><br /
><br />
<!-- ENDIF --></div>
<!-- IF not S_IS_BOT -->
{RUN_CRON_TASK}
<!-- ENDIF -->
ADD BEFORE
<div id="shoutbox_h" style="display:none;">
<div>
<div class="tbl-h-l">
<div class="tbl-h-r">
<div class="tbl-h-c">
<img style="padding-top:9px;padding-right:6px;float:right;cursor:pointer;"
src="./styles/black_pearl/theme/images/icon_minimize.gif"
onclick="javascript:ShowHide('shoutbox_nh','shoutbox_h','shoutbox_nh');"
alt="Shoutbox" />
<div class="tbl-title">
<h4>
Shoutbox
</h4>
<table class="tablebg" width="100%" cellpadding="0" cellspacing="0">
<td class="row1">
<span class="gensmall"> </span>
</td>
</table>
<div class="tbl-f-l">
<div class="tbl-f-r">
<div class="tbl-f-c"> </div>
<div id="shoutbox_nh">
tmp = 'shoutbox';
if(GetCookie(tmp) == '2')
ShowHide('shoutbox_nh', 'shoutbox_h', 'shoutbox_nh');
</script>
<div>
alt="Shoutbox" />
<h4>
Shoutbox
</h4>
<td>
<div style="font-size:1.2em; margin-bottom:20px;">
{SHOUTBOX}
<!-- ELSE -->
<div id="ajaxChatCopyright">
<a href="https://blueimp.net/ajax/">AJAX Chat</a> © <a href="https://blueimp.net">blueimp.net</a>
<!-- ENDIF -->
</td>
</table>
That should be all, it works
Much fun and luck for your own trials...
edit: shoutbox code changed. previous one was not correct!
#6 Tue 26 Feb, 2008 20:06 |
GlosterMan
Thanks this is the one I have installed in my sandbox installation and it shows hidden members online.
It is a great little chat and easy to install but I do not want to anger members that choose to remain hidden.
Rob
#7 Wed 27 Feb, 2008 20:54 |
GlosterMan
Huor
Thanks for all the great help and info
I sent you a PM
Rob "GlosterMan"
Greez...
#8 Wed 27 Feb, 2008 20:56 |
Huor
yw m8 - you got a PM back
#9 Wed 27 Feb, 2008 21:16 |
jorisaeles
I'm having some problems with the integration of the Ajax shoutbox
When I insert the line
'SHOUTBOX' => getShoutBoxContent(),
the shoutbox works perfect but the layout of the forum is totally changed, the font size is doubled. This only happens in Internet Explorer but it works perfect in Firefox!
[img=h**p://img135.imageshack.us/img135/6606/phpbb3ij7.th.png]
Could anybody help me to fix this? Thx
#10 Mon 28 Apr, 2008 21:33 |
cayoga
Huor wrote: [View Post] Mighty Gorgon wrote: [View Post] Huor wrote: [View Post] I also adapted the black pearl style to it.
<!-- IF U_ACP -->
<br />
<br />
</span><br /
><br />
{RUN_CRON_TASK}
<!-- ENDIF -->
ADD BEFORE
tmp = 'birthdays';
</script>
<div>
alt="Shoutbox">
<h4>
Shoutbox
</h4>
<td>
{SHOUTBOX}
<!-- ELSE -->
<a href="h**ps://blueimp.net/ajax/">AJAX Chat</a> © <a href="h**ps://blueimp.net">blueimp.net</a>
<!-- ENDIF -->
</td>
</table>
sorry for my english, i like to try this code, but how if i put that shoutbox at the top of forum...? i'm newbie...
#11 Fri 24 Oct, 2008 06:41 |
Huor
then just take the overall_header.html file instead and look for the proper position - below the menu i would recommend.
I changed the code for the shoutbox: Now it should be more usable
<div>
alt="Shoutbox" />
<h4>
Shoutbox
</h4>
<td class="row1">
</td>
</table>
tmp = 'shoutbox';
</script>
<div>
alt="Shoutbox" />
<h4>
Shoutbox
</h4>
<td>
{SHOUTBOX}
<!-- ELSE -->
<!-- ENDIF -->
</td>
</table>
<br />
#12 Fri 24 Oct, 2008 20:08 |
cayoga
Huor wrote: [View Post] cayoga wrote: [View Post] sorry for my english, i like to try this code, but how if i put that shoutbox at the top of forum...? i'm newbie...
<div>
alt="Shoutbox" />
<h4>
Shoutbox
</h4>
<td class="row1">
</td>
</table>
tmp = 'shoutbox';
</script>
<div>
alt="Shoutbox" />
<h4>
Shoutbox
</h4>
<td>
{SHOUTBOX}
<!-- ELSE -->
<!-- ENDIF -->
</td>
</table>
<br />
still not show the box for i write a message for shoutbox ...
#13 Mon 27 Oct, 2008 04:14 |
motoxtreme
anyone hv chat_body.html for Black Pearl ??
#14 Tue 11 Nov, 2008 13:39 |
Itsacraig
Hi, I am trying to implement the Ajax Chat, and trying to follow the instructions to what i need to edit in the functions.php script, but I got a feeling Im gonna end up with bugs due to syntax and what I should be adding exactly, so was wondering if someone could assist me with this?
I will highlight the bits in the following code I need help with..
function getShoutBoxContent()
global $phpEx, $phpbb_root_path;
// Get the URL to the chat directory:
if (!defined('AJAX_CHAT_URL')) WHEN IT ASKS FOR THE CHAT URL HERE, DO I INCLUDE HTTP:// ?
define('AJAX_CHAT_URL', $phpbb_root_path . 'chat/'); AND I ADD THE SAME AS ABOVE HERE??
// Get the real path to the chat directory:
if (!defined('AJAX_CHAT_PATH')) DO I NEED TO EDIT THIS BIT? IF SO, DO I ADD EXACTLY THE SAME???
if (empty($_SERVER['SCRIPT_FILENAME'])) IT NOW JUST ASKS FOR THE SCRIPT NAME, DO I SIMPLY ENTER INDEX.PHP HERE?
$_SERVER['SCRIPT_FILENAME'] = $_SERVER['DOCUMENT_ROOT'] . $_SERVER['SCRIPT_URL']; AND IT ASKS FOR THE SCRIPT NAME AGAIN AND SCRIPT FILE NAME. WHAT SHOULD BE PUT HERE???
define('AJAX_CHAT_PATH', realpath(dirname($_SERVER['SCRIPT_FILENAME']) . '/chat') . '/'); AND HERE AGAIN FOR BOTH CHAT PATH AND SCRIPT FILE NAME
// Validate the path to the chat:
if (@is_file(AJAX_CHAT_PATH . 'lib/classes.' . $phpEx)) AND WHAT DO I ENTER HERE IN ALL THESE SECTIONS?
// Include Class libraries:
require_once(AJAX_CHAT_PATH.'lib/classes.' . $phpEx);
// Initialize the shoutbox:
$ajaxChat = new CustomAJAXChatShoutBox();
// Parse and return the shoutbox template content:
return $ajaxChat->getShoutBoxContent();
return null;
#15 Sun 14 Feb, 2010 19:18 |
Similar Topics
Similar Topics
