Ok I already have a mod built and working perfectly.
The thing is I would like it to be apart of IP. I tried adding it in myself but no luck.
I was wondering if someone can do it for me, or help me out or somthing. Give me a boost in the right direction and tell me where to begin. Thanks.
You can see the example of the mod I want into IP.
www.tracker.crotorrent.com
Everything you see there I would like to be part of IP. But using the IP themes and everything.
on a side note, on the site I just showed you, how does it switch pages so smoothly?
Vuki
Adding New Mod
Subject: Re: Adding New Mod
Don't know what do yo exactly want!!!
I only get a login form.
Do you have test user?
yes I do now.
Username: test
Password: resetthisnow
Basicly its a tracker cms for bit torrents. I would like for someway the features on that site to be added onto the IP if its possible. So like the share ratio and downloaded and uploaded and all that stuff. Also to be updated in realtime like this site would.
Username: test
Generation Time: 0.0849s (PHP: 19% SQL: 81%)
