that is running with Versión de phpBB: 2.0.23
a friend said me that how is phoenix is based in phpbb version, then i must to used the convertor that have phpbb3 for to convert icyphoenix to phpbb3.
in this moment, i have created two sites,
site a) is a copy exactly of my icyphoenix in other part of my server (and running perfectly).
site b) in this site i have installed phpbb3
then, i use the convertor for to convert my icyphoenix to phpbb3, but when i used this, apperead a wrong, this wrong is this:
phpbb3 have the option to use again the convert and show this options
- new convert
- continue previously started convertion
obvius when i try to "continue previously started convertion" appeared again the wrong.
a men of phpbb.com said me this
gara,
Re: Unknown encoding.
The convertor looks in lang_main.php to see what encoding your phpBB2 board is using. I am not familiar with IcyPhoenix, but look to see if you have a lang_main.php in your board's default language folder and that it has '$lang_encoding' = 'whatever the encoding is';
Whenever a conversion starts and fails, you do get the option to "Continue the Conversion" or "New conversion." By selecting "Continue Conversion," the convertor will pick up where it left off at the error message. This savaes you having to restart the conversion all over again.
i searched in my language default (of my forum where i have icyphoenix) the file lang_main.php but in this file i don't find a line with $lang_encoding or lang_encoding i try to search in others files but never i find this lines..
for this and how this forum is about icyphoenix, i need that somebody help me to solved this wrong.
if somebody has converted icyphoenix to phpbb3 I would be grateful to him that he can explain me as he did it.
and i would like to know if exist other form to convert icyphoenix to phpbb3
thanks
