Re: Picture Posting And Url Posting
You can as another option;
Upload the image has an attachment within the post using the attachment feature, by default the attachment mod will allow the upload of .gifs, .jpg, .png, but not .bmp file extensions.
It is suggested though the image size is reduced to 800 pixels wide or less this will allow the image to be sized to fit most modern monitors set to a resolution 1024 x 768 or higher without the need for the generation of the horizontal scroll bar in IE or Firefox and/or other browsers.
Your other option would be to use the code "img]http://www.website.com/images/nameoffiletodisplay.jpg[/img" (I have taken out the opening and closing brace's so you can see the code line), what this does it point the code to a location on the web site were the image is stored, NOTE this only works if the image already exists in that location, if it does not then you will need to upload it to that location via FTP.
The final option is as stated before use the buttons at the top of the posting edit page, these will correctly insert the code for linking, but you will still have to link to an image that is already on the web site file store.
I also just spotted this option, if you click on the button at the top of the post edit page that looks like this
you will be directed to postimage.org which allows you to upload an image to their servers and then creates the link code for insertion into your post to display the image.
Hope this helps
