Need HTML Code In Gallery
Subject: Need HTML Code In Gallery
Hello to all, this site is Awsome!
i have a small request to ask, im running Intrgamod 1.4.1 You can see the site here, its a phpbb 2.0.23 modded forum with gallery
Photo Album Powered by
Photo Album 2.0.53 © 2002-2003 Smartor
Volodymyr (CLowN) Skoryk's SP1 Addon 1.5.1
IdleVoid's Album Category Hierarchy 1.3.0
Mighty Gorgon Full Album Pack 1.2.3
the album is a nice gallery for what i use it for but i need to know if there is a way for me to get the pictures to make a html code like in this picture, dont need the others, i wont to add alot of pictures to my gallery but i wont to be able to use them on peoples Myspace sites, most people dont know how to right a html script for a picture, hope some one can help me on this ive looked all over the place to try and find something that would do it, but cant find any thing
my gallery already makes this, Thank you for your time
  1. [albumimg]9[/albumimg]
picture_codes
Subject: Re: Need HTML Code In Gallery
Yes the albumimg bbcode is included in icy-Phoenix. Look:
  1. [albumimg mode=full]105[/albumimg]
  1. [albumimg]105[/albumimg]
I think he actually is asking for the html, link code to show with his images as in the picture he provided...
:mrgreen:
yes that is what i need just the HTML code to show with picture, if it is possable to modafie the gallery to show the html code when adding a picture
You can simply modify album_showpage.tpl and insert the code you need.
Since the code is based to your picture link you don't need to edit the PHP part, but you may hardcode it in the template.
Try to start by duplicating the BBCode input box and applying some modifications. I'm sure you will succeed.
well i would but... i know nothing about coding and i cant seem to find the code to use, any where, i might be wording the search wrong when im looking for the code. all i keep finding is html web generators, that help build web sites, nothing for adding to a album to generate a code like what photo bucket has.
but thanks for replying , have asked on 2 or 3 forums about code for the gallery, and no one even answers me, guess its not a easy code to do? and i ran across this site and your name was listed in the the mod discription
so i thought i would ask here,
but thanks again for replying.genie
It is not difficult... but it requires time for me to make this changes for you and unfortunately currently I am a bit short of it.
The part of the code you should look at is the following:
<td valign="top" align="right"><span class="genmed">{L_PIC_BBCODE}:</span></td>
<td valign="top" align="left"><form name="select_all" action=""><input class="post" name="BBCode" size="50" maxlength="100" value="{PIC_BBCODE}" type="text" readonly="readonly" onClick="javascript:this.form.BBCode.focus();this.form.BBCode.select();" /></form></td>
Try to play with this code and let me know.
I think this is close to what I would like. I need a row right below the bbcode with the actual link to the photos
Ideally it would look like this with the direct link added. Any tips on the code to add for this??
Poster: PaulLear
Image: Side View x 2 ...just in case Adam can live with a photo instead of the real thing!
Image Details: ID: 1059 - Image Type: JPG - Size: 780 x 560 (152KB)
BBCode: [albumimg ] 1059 [ /albumimg]
direct photo link http://example.com//httpdocs/forum/...567gt783456.jpg
Posted: 13 Apr 2008 09:36 PM
Rating: Not Rated
So anyone knows the solution?
quiet on old topic you´re re-animating
i´m not even shure that FAP is still avaible
Generation Time: 0.1703s (PHP: 11% SQL: 89%)
