macxr8
 FAP SUPPORT - FAP On A CH Modded Board
I am trying to install FAP, using a CH modded board. Some of the lines in the files are not there so dont know where to put them....
I have been told by some of the guys over at CH that FAP should work with CH, but I can't seem to do it.
Any help be appreciated
#1 Fri 04 Apr, 2008 14:13 |
KasLimon
 Re: FAP On A CH Modded Board
If you can not find the lines specified, just try to do partial searchs...
But Ptirhiik has a lot of knowledge about programming and have modified hugely phpBB so I think if you do partial searchs you'll not find it neither...
Please tell us which instructions you can't find and we'll try to help you.
Also, your CH version would help
Greets!
____________ Gabriel Anca
#2 Fri 04 Apr, 2008 15:12 |
macxr8
yea realised after some more info would be handy
Anyhow, CH ver 2.1.6g
PHPbb ver 2.0.22
- #-----[ OPEN ]------------------------------------------------
- admin/index.php
- #-----[ FIND ]------------------------------------------------
- case PAGE_FAQ:
- $location = $lang['Viewing_FAQ'];
- $location_url = "index.$phpEx?pane=right";
- break;
- #-----[ AFTER, ADD ]------------------------------------------
- // Mighty Gorgon - Full Album Pack - BEGIN
- case PAGE_ALBUM:
- $location = $lang['View_Album_Index'];
- break;
- case PAGE_ALBUM_PERSONAL:
- $location = $lang['View_Album_Personal'];
- break;
- case PAGE_ALBUM_PICTURE:
- $location = $lang['View_Pictures'];
- break;
- case PAGE_ALBUM_SEARCH:
- $location = $lang['Album_Search'];
- break;
- // Mighty Gorgon - Full Album Pack - END
- templates/subSilver/overall_header.tpl
- [ FIND]
- {L_USERGROUPS}</a>
This one I am using a customized version and it doesnt have much in it.
here is my overall_header.tpl
- <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
- <html dir="{S_CONTENT_DIRECTION}">
- <link rel="stylesheet" href="templates/subSilver/FAP.css" type="text/css" />
- <head>
- <meta http-equiv="Content-Type" content="text/html; charset={S_CONTENT_ENCODING}">
- <meta http-equiv="Content-Style-Type" content="text/css">
- {META}
- {NAV_LINKS}
- <title>{SITENAME} :: {PAGE_TITLE}</title>
- <link rel="stylesheet" href="templates/c3s/{T_HEAD_STYLESHEET}" type="text/css">
- <!-- BEGIN switch_enable_pm_popup -->
- <script language="Javascript" type="text/javascript">
- if ( {PRIVATE_MESSAGE_NEW_FLAG} ) {
- window.open('{U_PRIVATEMSGS_POPUP}', '_phpbbprivmsg', 'HEIGHT=225,resizable=yes,WIDTH=400');
- function newImage(arg) {
- if (document.images) {
- rslt = new Image();
- rslt.src = arg;
- return rslt;
- function changeImages() {
- if (document.images && (preloadFlag == true)) {
- for (var i=0; i<changeImages.arguments.length; i+=2) {
- document[changeImages.arguments[i]].src = changeImages.arguments[i+1];
- var preloadFlag = false;
- function preloadImages() {
- over_profile = newImage(/*URL*/'templates/c3s/images/profile_on.jpg');
- over_faq = newImage(/*URL*/'templates/c3s/images/faq_on.jpg');
- over_search = newImage(/*URL*/'templates/c3s/images/search_on.jpg');
- over_memberlist = newImage(/*URL*/'templates/c3s/images/memberlist_on.jpg');
- over_usergroups = newImage(/*URL*/'templates/c3s/images/usergroups_on.jpg');
- over_register = newImage(/*URL*/'templates/c3s/images/register_on.jpg');
- over_preferences = newImage(/*URL*/'templates/c3s/images/preferences_on.jpg');
- over_pms = newImage(/*URL*/'templates/c3s/images/pms_on.jpg');
- over_login = newImage(/*URL*/'templates/c3s/images/login_on.jpg');
- preloadFlag = true;
- </script>
- <!-- END switch_enable_pm_popup -->
- </head>
- <body onLoad="preloadImages();" bgcolor="{T_BODY_BGCOLOR}" text="{T_BODY_TEXT}" link="{T_BODY_LINK}" vlink="{T_BODY_VLINK}" leftmargin="0" marginheight="0" marginwidth="0" topmargin="0">
- <table width="805" height="190" border="0" align="center" cellpadding="0" cellspacing="0">
- <tr>
- <td rowspan="5"><a name="top"></a><img src="templates/c3s/images/header_01.jpg" width="44" height="137" alt=""></td>
- <td rowspan="5"><img src="templates/c3s/images/header_02.jpg" width="42" height="137" alt=""></td>
- <td colspan="2"><img src="templates/c3s/images/header_03.jpg" alt="" width="94" height="40" border="0"></td>
- <td colspan="3"><a href="{U_MEMBERLIST}" onMouseOut="changeImages('Memberlist','templates/c3s/images/memberlist.jpg')" onMouseOver="changeImages('Memberlist','templates/c3s/images/memberlist_on.jpg')"><img src="templates/c3s/images/memberlist.jpg" name="Memberlist" width="173" height="40" border="0"></a></td>
- <td rowspan="7"><a href="http://www.trueblueford.com/index2.html"><img src="templates/c3s/images/header_05.jpg" alt="" width="111" height="189" border="0"></a></td>
- <!-- BEGIN switch_user_logged_out -->
- <td colspan="3"><a href="{U_REGISTER}" onMouseOut="changeImages('Reg','templates/c3s/images/register.jpg')" onMouseOver="changeImages('Reg','templates/c3s/images/register_on.jpg')"><img src="templates/c3s/images/register.jpg" name="Reg" width="177" height="40" border="0"></a></td>
- <!-- END switch_user_logged_out -->
- <!-- BEGIN switch_user_logged_in -->
- <td colspan="3"><a href="{U_PREFERENCES}" onMouseOut="changeImages('Pref','templates/c3s/images/preferences.jpg')" onMouseOver="changeImages('Pref','templates/c3s/images/preferences_on.jpg')"><img src="templates/c3s/images/preferences.jpg" name="Pref" width="177" height="40" border="0"></a></td>
- <!-- END switch_user_logged_in -->
- <td colspan="3"><img src="templates/c3s/images/header_07.jpg" width="117" height="40" alt=""></td>
- <td rowspan="5"><img src="templates/c3s/images/header_08.jpg" width="17" height="137" alt=""></td>
- <td rowspan="5"><img src="templates/c3s/images/header_09.jpg" width="29" height="137" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="1" height="40" alt=""></td>
- </tr>
- <tr>
- <td colspan="3"><a href="{U_SEARCH}" onMouseOut="changeImages('Search','templates/c3s/images/search.jpg')" onMouseOver="changeImages('Search','templates/c3s/images/search_on.jpg')"><img src="templates/c3s/images/search.jpg" name="Search" width="181" height="35" border="0"></a></td>
- <td colspan="2"><img src="templates/c3s/images/header_11.jpg" width="86" height="35" alt=""></td>
- <td colspan="2"><img src="templates/c3s/images/header_12.jpg" width="89" height="35" alt=""></td>
- <td colspan="3"><a href="{U_GROUP_CP}" onMouseOut="changeImages('Usergroups','templates/c3s/images/usergroups.jpg')" onMouseOver="changeImages('Usergroups','templates/c3s/images/usergroups_on.jpg')"><img src="templates/c3s/images/usergroups.jpg" name="Usergroups" width="183" height="35" border="0"></a></td>
- <td rowspan="2"><img src="templates/c3s/images/header_14.jpg" width="22" height="70" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="1" height="35" alt=""></td>
- </tr>
- <tr>
- <td rowspan="2"><img src="templates/c3s/images/header_15.jpg" width="70" height="41" alt=""></td>
- <td colspan="4" rowspan="2"><a href="{U_FAQ}" onMouseOut="changeImages('FAQS','templates/c3s/images/faq.jpg')" onMouseOver="changeImages('FAQS','templates/c3s/images/faq_on.jpg')"><img src="templates/c3s/images/faq.jpg" name="FAQS" width="197" height="41" border="0"></a></td>
- <td colspan="4"><a href="{U_PRIVATEMSGS}" onMouseOut="changeImages('PM','templates/c3s/images/pms.jpg')" onMouseOver="changeImages('PM','templates/c3s/images/pms_on.jpg')"><img src="templates/c3s/images/pms.jpg" name="PM" width="196" height="35" border="0"></a></td>
- <td><img src="templates/c3s/images/header_18.jpg" width="76" height="35" alt=""></td>
- </tr>
- <tr>
- <td rowspan="3"><img src="templates/c3s/images/header_19.jpg" width="84" height="49" alt=""></td>
- <td colspan="5" rowspan="3"><a href="{U_LOGIN_LOGOUT}" onMouseOut="changeImages('LogIn','templates/c3s/images/login.jpg')" onMouseOver="changeImages('LogIn','templates/c3s/images/login_on.jpg')"><img src="templates/c3s/images/login.jpg" name="LogIn" width="210" height="49" border="0"></a></td>
- <td><img src="templates/c3s/images/spacer.gif" width="1" height="6" alt=""></td>
- </tr>
- <tr>
- <td colspan="4" rowspan="2"><a href="{U_PROFILE}" onMouseOut="changeImages('Profile','templates/c3s/images/profile.jpg')" onMouseOver="changeImages('Profile','templates/c3s/images/profile_on.jpg')"><img src="templates/c3s/images/profile.jpg" name="Profile" width="215" height="43" border="0"></a></td>
- <td rowspan="3"><img src="templates/c3s/images/header_22.jpg" width="52" height="73" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="1" height="21" alt=""></td>
- </tr>
- <tr>
- <td colspan="2" rowspan="2"><img src="templates/c3s/images/header_23.jpg" width="86" height="52" alt=""></td>
- <td colspan="2" rowspan="2"><img src="templates/c3s/images/header_24.jpg" width="46" height="52" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="1" height="22" alt=""></td>
- </tr>
- <tr>
- <td colspan="4"><img src="templates/c3s/images/header_25.jpg" width="215" height="30" alt=""></td>
- <td colspan="6"><img src="templates/c3s/images/header_26.jpg" width="294" height="30" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="1" height="30" alt=""></td>
- </tr>
- <tr>
- <td><img src="templates/c3s/images/spacer.gif" width="44" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="42" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="70" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="24" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="87" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="34" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="52" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="111" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="84" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="5" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="88" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="19" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="76" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="22" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="17" height="1" alt=""></td>
- <td><img src="templates/c3s/images/spacer.gif" width="29" height="1" alt=""></td>
- <td></td>
- </tr>
- </table>
- <br />
- {CALENDAR_BOX}
- <!-- Start CH IMPortal -->
- <table width="100%" border="0" cellspacing="0" cellpadding="0">
- <tr>
- {PORTAL_HEADER}
- <td width="10"><img src="{I_SPACER}" alt="" width="10" height="30" /></td>
- <td valign="top">
- <!-- Finish CH IMPortal -->
thats about it.
I have done all the other editing, and from the ACP it seems to be working from there.
Again any help appreciated.
#3 Sat 05 Apr, 2008 13:07 |
KasLimon
No problem
I think this would work: #
includes/class_stats_online.php
PAGE_GROUPCP => array('txt' => 'Viewing_groups', 'url' => $this->mode == 'in_admin' ? 'admin/index' : 'groupcp', 'parms' => $this->mode == 'in_admin' ? array('pane' => 'right') : array()),
PAGE_ALBUM => array('txt' => 'View_Album_Index', 'url' => $this->mode == 'in_admin' ? 'admin/index' : 'album', 'parms' => $this->mode == 'in_admin' ? array('pane' => 'right') : array()),
PAGE_ALBUM_PERSONAL => array('txt' => 'View_Album_Personal', 'url' => $this->mode == 'in_admin' ? 'admin/index' : 'album', 'parms' => $this->mode == 'in_admin' ? array('pane' => 'right') : array()),
PAGE_ALBUM_PICTURE => array('txt' => 'View_Pictures', 'url' => $this->mode == 'in_admin' ? 'admin/index' : 'album', 'parms' => $this->mode == 'in_admin' ? array('pane' => 'right') : array()),
PAGE_ALBUM_SEARCH => array('txt' => 'Album_Search', 'url' => $this->mode == 'in_admin' ? 'admin/index' : 'album', 'parms' => $this->mode == 'in_admin' ? array('pane' => 'right') : array()),
#-----[ AFTER, ADD ]------------------------------------------------
<td colspan="4" rowspan="2"><a href="{U_ALBUM}" onMouseOut="changeImages('ALBUM','templates/c3s/images/album.jpg')" onMouseOver="changeImages('ALBUM','templates/c3s/images/album_on.jpg')"><img src="templates/c3s/images/album.jpg" name="ALBUM" width="197" height="41" border="0"></a></td>
You'll have to create templates/c3s/images/album.jpg and templates/c3s/images/album_on.jpg images.
Greets!
#4 Sat 05 Apr, 2008 15:47 |
macxr8
seems to be working ok my test PC.
however I have found another piece of code
- viewonline.php
- case PAGE_FAQ:
- $location_url = "faq.$phpEx";
- break;
- case PAGE_ALBUM:
- $location_url = "album.$phpEx";
- break;
- $location_url = "album_personal_index.$phpEx";
- break;
- break;
- break;
thanks for your help
#5 Mon 07 Apr, 2008 12:47 |
KasLimon
I think this modification is unnecessary. Ask a user to enter album search and then go to Who is online section.
It should show the user is in album search. If it doesn't, I'll search the solution
Greets!
#6 Tue 08 Apr, 2008 10:02 |
macxr8
thanks, that all seems to be working well now, so far am limiting access to certain members of the board to help debug it then I will release to all members
#7 Thu 10 Apr, 2008 14:17 |
| Link this topic |
| URL |
| BBCode |
| HTML |
