Post Milky Way Style Won't Show Some Buttons Up
Hello,
I installed the nice lookin' Milky Way style but i'm having a problem, some buttons like EDIT, DELETE, and other graphics for ONLINE STATUS, etc are not showing up!!
any idea what causes this? please help! thank you.
dart vaderSend private message
Post Re: Milky Way Style Won't Show Some Buttons Up
Make sure you upload all files.
xmenfileSend private message
thanks xmenfile,
but I'm very sure everything is up there.
I m using this style too and it works fine.   If all files there, then try to clear cache.
I think i can try that and see what happens.
but before,
in my first post I forgot to mention that I got a spanish language pack installed at my forum. You think this may be causing the problem?
Icy 1.2.0.27 is a new version, in this version changed some image folders.
The rest of images should work well.
thank you The KuKa but a have no Icy installed
I just have a spanish traslated phpbb3 board recently installed, uploaded the Milky Way style files and installed it, but many  of the buttons are not showing up!
here's a screenshot from inside a thread:
svl36x
important fact, when the board is set in English language everything looks just fine, but not when I turn it to spanish language
thnks for the help!
dart vader wrote: [View Post]
thnks for the help!
Uhm... I think this is the problem.
I've never worked on phpBB3 but looking at tha package I'd try this: in styles/milky_way/imageset , where you have the en folder, create a new folder and name it exactly like the folder you use for language file, the one located in language/ (the other one than "en" ). In this folder, copy and paste all images you have in styles/milky_way/imageset/en .
Let me know if it works.
sorry, I'm working in two projects right now and had to put this one aside for a few days, but i'm back.
Vortex,
you rock man!
of course, the problem was in this spanish folder images name!
what i did was to rename folder from es to es-ar and it was done
thnks all folks for helping me on this issue.
Glad you solved ^^
