Post Medieval Buttons
Hi!
I'm searching a buttons pack (in english or spanish) with a "medieval" style (like papyrus or parchment). I can't find it, and I maybe you could help me.
If you don't know any pack like this, please, I would conform with a pack of buttons that looks good and integrates perfectly in a medieval skin.
Thanks a bunch mates
PD: Sorry for my pathethic and painful english
SarkenSend private message
Post Re: Medieval Buttons
h**p://forums.phpbb-fr.com/viewforum_87.html
It's in French, SGo made some medieval stuff, and it may give you basis to make a full set for IP - but I'm sure you'll work something out.
Lopalong wrote: [View Post]
http://forums.phpbb-fr.com/viewforum_87.html
Hi! Thanks for the information. But my english it's really really bad, and I can't find any medieval theme or base in the forum. Do you know the link?
See you
http://www.phpbb-fr.com/demo_templates/phpBB2/index.php
The template is MylGrimoire.
hal9000Send private message
Gracias Hal, de todas formas estaba buscando algo un pelín más profesional, no se, un acabado más convincente, aún así, muchas gracias
Sarken wrote: [View Post]
Hi Sarken, with the above quote, I don't know if you have either found what you are looking for, or still need some help to track down something suitable.
Anyway, I don't know if this is the sort of thing you want, so maybe a screenshot / link of what you are using would give a better impression of what you are after.?
Google Translation:
Hola Sarken, con la cita anterior, no sé si tiene ya sea encontrado lo que busca, o que aún necesita algo de ayuda para encontrar algo apropiado.
De todos modos, no sé si este es el tipo de cosas que desea, por lo que tal vez una captura de pantalla y vínculo de lo que está usando daría una mejor impresión de lo que está después.?
Demos: h**p://***.mylimages.com/index_demo.html
Downloads: h**p://***.mylimages.com/prive/viewtopic.php?p=3#p3
Theme - MylCastel.
Filesize: 5.13 KB
Viewed: 14376 Time(s)
Filesize: 1.88 KB
Filesize: 1.87 KB
English Please.
@Sarken: I do not know any imageset as you ask. Sorry for adding no new things...
Traducing:
Edited by novice programmer, Fri 18 Apr, 2008 22:55: Edited something.... (added translation) ;)
I'm experimenting trying to create the buttons for the site I'm working on. May be you like it:
Filesize: 8.79 KB
Viewed: 14236 Time(s)
Here's an interesting website if one is looking for ideas?
h**p://***.fotolia.com/tag/medieval+scroll?offset=0
Hi!
Thanks for all the replies.
Hal, your button of "Nuevo tema" looks really really good, I wanna be noticed if you finish them
I'm working also on medieval buttons, if I finish a pack I'll post it here =)
See you
Thanks Sarken.
I've finished and these are the buttons I made. I hope to see yours when finished too.
botones pergamino.rar
Filename: botones pergamino.rar
Filesize: 382.61 KB
Downloaded: 372 Time(s)
Filename: muestra botones pergamino.jpg
Filesize: 69.85 KB
Downloaded: 331 Time(s)
hal9000 wrote: [View Post]
Thanks Sarken.
WoW! Amazing pack
What software did you use?
WoW! Amazing pack
Thanks Sarken.
I used Corel Photo-Paint.
Really nice buttons.
