Post Solved-BBcode Works Except Images "No Image Icon"
I know this is minor problem, but last time this happened, someone came out with a php argument for a certain .tpl or other file.
Everything with BBcode works, except no images. Everything in ACP and profile is on. (Album images work fine).
My .htaccess file has a lot of stuff in it. Maybe there's something to correct there.
Thanks in advance.
My main IP 1.3 site
My IP 1.3 styles test site
gearheadSend private messageVisit poster's website
Post Re: BBcode Works Except Images "No Image Icon" Sho
I didn't understand. Are you displied a "No image" icon or a "No thumbnail" icon?
Can you please link this image?
dNowSend private messageVisit poster's website
main%2Ffiles%2Fposted_images%2Fuser_2_gt5p.jpg" class="highslide" onclick="return hs.expand(this)">image_thumbnail.php-pic_id-http-3a-2f-2fwww.portal.thegtsaga.net-2f-main-2ffiles-2fposted_images-2fuser_2_gt5p
That's what I get. I gave you the exact URL of the image or "no image".
That's what's displayed instead of the real image.
My main IP 1.3 site
I noticed just now since the upgrade to 1.2027
I get this in the ACP for the settings to limit image size in the forums:
Compatibility checks
getimagesize() URL support
Available in PHP 4.0.5     Available
The MOD is able to retrieve image dimensions
URL-aware fopen wrappers
Set allow_url_fopen to Yes in your php.ini     Unavailable
The MOD cannot generate a fingerprint of the file, and is therefore unable to cache the image dimensions
openSSL extension loaded
Load the openssl.dll extension in your php.ini     Available
The MOD in able to retrieve dimensions from https:// images so is able to cache them
Maybe I need to set the php to allow open wrappers?
Just a thought.
My main IP 1.3 site
Create a file php.ini (if you don't already have one) in the public folder and add the script below:
; Fopen wrappers ;
; Whether to allow the treatment of URLs (like h**p:// or f*p://) as files.
allow_url_fopen = On
allow_url_include = On
Chmod it to: 644, though some say "local" php.ini may need Chmod to 705
Local php.ini should over-write the global php.ini unless the IP has screwed up ?
Lets see what happens.
Thank you. I will give that a try!
P.S. there is no "public" folder. If so, there must be a root folder. I cannot find a "public" folder.
thanks.
My main IP 1.3 site
A Public Folder by many other names.
It's the folder your forum root-folder is placed in. And if it's a shared server, it's probably the root anyway?
I contacted my host. They said that I have to modify my php. The only way they show how is with shell commands. I am not good at that type stuff. I tried some, but I got in too deep.
They do not normally allow fopen wrappers. I can make it happen if I was good with shell ftp commands.
But I might as well just be happy the way it is. It's more secure. Thanks to MG., and my host.
My main IP 1.3 site
Post Re: Solved-BBcode Works Except Images "No Image Icon&qu
I found the trick. It's just like some of the earlier versions of IP.
You have to toggle the radio button for images in posts.
ACP>configuration>Icy Phoenix>Images in posts>
I had to toggle the button to "no" images in posts. Then my images, signatures, etc. are now showing.
When I toggle it back to "yes", then the images, sigs, etc. do not show.
My main IP 1.3 site
