Post Thanks Button & Similar Topics For Icy_Silver
I just customize the Icy_Silver for lastest IP, but noticed there are not Thanks button and Similar topics block.  They work on Icy Phoenix, but not Icy_Silver.  Can anyone help me how to fix it?
Thank you,
xmenfileSend private message
Post Re: Thanks Button & Similar Topics For Icy_Silver
check to make sure that the images are not a differant file type is so then simply edit the template and change the temp to direct to the correct images!
DxL- Design Is Everything
GMX TopSites - Free Links
dxlwebsSend private messageVisit poster's website
xmenfile wrote: [View Post]
Thank you,
That is not possible because template files are exactly the same of standard template: both are based on mg_themes folder.
Maybe you didn't install the theme folder or you don't have those features enabled in ACP.
Try to check!
