How To Change Main Menu Buttons / Links In Milky Way?
Subject: How To Change Main Menu Buttons / Links In Milky Way?
Hello there,
How can I change the top menu buttons?
I mean the Home Forum New (xx) Profile Search FAQ Log out.
My style has New PMs, witch I want to remove and add New posts.
Thanks!
Subject: Re: How To Change Main Menu Buttons / Links In Milky Way?
Edit overall_header.html
Thanks man :)
For the rest of the people:
OPEN overall_header.html
<!-- IF S_DISPLAY_PM --><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a><!-- IF PRIVATE_MESSAGE_INFO_UNREAD --><a href="#"> / </a><a href="{U_PRIVATEMSGS}" class="PM-new-link">{PRIVATE_MESSAGE_INFO_UNREAD}</a><!-- ENDIF -->&nbsp;&nbsp;<img src="{T_THEME_PATH}/images/menu_sep.png" alt="" />&nbsp;<!-- ENDIF -->
ADD BEFORE OR AFTER
<a href="search.php?search_id=newposts">New Posts</a>&nbsp;&nbsp;<img src="{T_THEME_PATH}/images/menu_sep.png" alt="" />&nbsp;
You can also hide in comments or delete the PMs code if you don't want it :)
Generation Time: 0.0843s (PHP: 25% SQL: 75%)
