rasputin007
 No Background/style With IP1.2.0.27b
I have a huge problem!
I have installed IP 1.2.027b on 2 different locations
Site1 and Site2,
but I always have a plain white background.
On site 2 I installed additional styles which where accepted in the ACP, but whatever style I choose it always stays white.
I have made sure that I have set all permissions correctly before setting up IP 1.2.0.27b.
I have a phpBB3 forum, but wanted a shoutbox, so I tried to install ajax-chat into my backup forum (phpBB3) and made a total mess of it. So I thought I'll try IP, mainly Black Pearl and Rainbow Pearl are choices on my phpBB3 forum.
Any help where I have gone wrong would be much appreciated. (It might have been mentioned somewhere already in this forum, but after 2 days of looking I have not found it, Sorry!)
#1 Mon 26 May, 2008 19:48 |
Bobocop
 Re: No Background/style With IP1.2.0.27b
That ussualy happens when your url path is wrong, (pointing to the wrong page)
for example your url is Forum/index.php, mine is forum.php
make sure you have the paths setup properly in your ACP under --> Configuration --> Server
and make sure you point the url to the right page
Edited:
It looks like you installed IP (site 2) in a subfolder called "Forum" under the domain " rasputin007.co.uk " (correct me if i'm wrong)
if so, make sure the "Script path" in your ACP is set like this --> /Forum/
then you would use this --> http://www.rasputin007.co.uk/Forum/
to point to your site
#2 Tue 27 May, 2008 00:26 |
rasputin007
I have IP setup in subfolders like "Forum", is easier when you have quite a bit of stuff in it. Site1 is also in a subfolder and a subdomain, which should work fine (phpBB did!).
Thanks I will check those path, but if I remember correctly they were setup right automatically during installation.
I let you know what happend.
Update:
I have checked the path, cleared all cache on style and my Firefox browser, but it still remains white background, but also any icons are not present.
It is like you can see the page layout, but any background, borders,icons etc are missing.
#3 Tue 27 May, 2008 13:16 |
xmenfile
my opinion: make sure you upload all templates files and images. go to ACP change it back to Icy Phoenix style, remove and reinstall Milkyway style.
#4 Tue 27 May, 2008 17:25 |
rasputin007
Thanks for that reply.
I have downloaded IP1.2.0.27b again with Aphrodite style (is not part of IP, but installer looks for it) and will install it again.
#5 Tue 27 May, 2008 17:53 |
Bobocop
rasputin007, did you try linking to the site using the main domain (Not sub domain) and see if it works.
#6 Tue 27 May, 2008 22:27 |
rasputin007
Yes I tried, but no change. I attach a screenshot of ACP of site 2 (in the main domain)
| Description: |
ACP od Site 2 |
| Filesize: |
248.96 KB |
| Viewed: |
182 Time(s) |
#7 Tue 27 May, 2008 23:57 |
xmenfile
can you try w/o the www and clear your forum cache.
#8 Wed 28 May, 2008 00:26 |
Bobocop
Go to your --> CPanel --> Error Logs
and see what the last errors say, maybe that will give you a clue what file has an error or whats wrong.
If you have to many errors,
just delete them, then try to access your site, then go back to cpanel and check what error it gave you
#10 Wed 28 May, 2008 04:46 |
rasputin007
I get an Internal Server Error when accessing http://www.rasputin007.co.uk/Forum/templates (and other folders)
You only can access files that are there. If you try a folder you get that error message. That's how my webhosting company set it up.
Sorry did not had time today to do anything (have a V8 firmware that drives me mad!)
#11 Thu 29 May, 2008 00:54 |
Artie
Browsing to any folder in your installation should load a default index.html file like the one that displays here :
http://www.rasputin007.co.uk/Forum/blocks/
Do as Bobocop suggested and check your site's error log
#12 Thu 29 May, 2008 02:26 |
KugeLSichA
hi,
i have had this problem months ago too...
try to delete the .htaccess file in the templates folder
this should work...
let me know
#13 Thu 29 May, 2008 17:47 |
Inactive User
Can you indicate the "full" path from /forum/ to where the IP template folder is, because none of the paths are valid ?
#14 Fri 30 May, 2008 05:33 |
rasputin007
hi,
this should work...
let me know
That did it!!!
Besten Dank für den Tip! (Thanks for the hint!)
It is funny, but when I enter www.rasputin007.co.uk/Forum/templates/index.html I also get the server error. It does not matter if I use index.html or not it is always "Internal Server Error". Strange, but that is OK!
One more question, I use Rainbow Pearl on my phpBB3 forum (ColorizeIt version) and just love it, but I can not find Rainbow Pearl for IP, does it has a different name or is it not available for IP?
Thanks again to everybody for their help, very much appreciated!
#15 Fri 30 May, 2008 23:50 |
| Link this topic |
| URL |
| BBCode |
| HTML |
