Re: Frozen Phoenix
i think all styles here at icyphoenix.com will be release when new ip version is released.....
but when you can't wait then use the icyphoenix svn version. for svn version is frozen phoenix already available >> http://www.icyphoenix.com/viewtopic.php?f=1&t=4608
If you are going to suggest that people download anything from SVN, then please also advise them that the Themes / Styles template configurations are also quite different from IP v1.2.0.27. And that no support will be given to make them backward compatible.
The time now is Fri 03 Apr, 2026 17:20 • All times are UTC + 1 Hour [DST enabled]
