Convert IP Translation From 1.1.0.15 To 1.2.0.27
Subject: Convert IP Translation From 1.1.0.15 To 1.2.0.27
Hi, I have made an unofficial bulgarian translation of the most common icy features (will share it as soon as i translate all files), and was wondering if there is an easy way to convert my V.1.1.0.15 to V.1.2.0.27 translation. Is there a change log of the things added in V.1.2.0.27, so I can just add them in my V.1.1.0.15 files? This will spare me quite some time :)
Subject: Re: Convert IP Translation From 1.1.0.15 To 1.2.0.27
Hmm, I don't think so... sorry
The best way I used for german is to use winmerge and to merge the old translation you have withe the new english one. Than you will find the new lang var
And take a look of the file date
Danke für den Tip TheSteffen :)
I guess it's still something after all.
Yes... WinMerge is the best way in any case.
You should compare old english files with new ones to understand what is changed... and replicate the changes in your lang files.
Generation Time: 0.2789s (PHP: 6% SQL: 94%)
