I was wondering if someone could tell me what this piece of code is for....I understand it is part of the cms but I was wondering what is its function...
it is in includes/page_header.php
if( empty($gen_simple_header) && (!defined('HAS_DIED')) && (!defined('IN_LOGIN')) && ( ($cms_wide_blocks == true) || !empty($cms_page_id) ) && ($board_config['board_disable'] == false) )
$template->assign_block_vars('switch_importal', array(
'SPACER' => $images['spacer'],
$template->set_filenames(array('portal_header' => 'portal_page_header.tpl'));
cms_parse_blocks($cms_page_id, !empty($cms_page_id), $cms_wide_blocks, 'header');
$template->assign_var('PORTAL_HEADER', cms_assign_var_from_handle($template, 'portal_header'));
$template->set_filenames(array('portal_headerleft' => 'portal_page_headerleft.tpl'));
if (cms_parse_blocks($cms_page_id, !empty($cms_page_id), $cms_wide_blocks, 'headerleft'))
$template->assign_var('HEADER_WIDTH', $cms_config_vars['header_width']);
$template->assign_var('PORTAL_HEADERLEFT', cms_assign_var_from_handle($template, 'portal_headerleft'));
$template->set_filenames(array('portal_headercenter' => 'portal_page_headercenter.tpl'));
if (cms_parse_blocks($cms_page_id, !empty($cms_page_id), $cms_wide_blocks, 'headercenter'))
$template->assign_var('PORTAL_HEADERCENTER', cms_assign_var_from_handle($template, 'portal_headercenter'));
and this smal bit found in the same file
thanks for any help.
hampshire
